I just added the Airstream Forum App to my iPad and this is my first post!
A year ago I purchased a 1975
Sovereign Airstream 31'. Then I had a certified camper repairman to repair and check out all electrical and plumbing. All exterior lights are working and all kitchen appliances, air conditioner, water heater, bathroom/ holding tanks in working order.
Current problem: I have several windows that drip water from the inside and one drip over the back bedroom twin bed area on the right(only ceiling drip) - Should I seal from outside with silicone? or what should I use?
OR should I replace seals in windows? I hope that I can stop leaks at windows without replacing seals! The person I purchased the airstream from also noted problems with leakage at windows. Thanks for your help, Elaine
