Old 06-24-2013, 12:48 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Window gasket release solution?
We seem to always struggle to get our front and side windows to release. The glass likes to stick to the rubber gasket. We heard that there was a lube or release agent that could be applied to help with this. Does anyone happen to know what that might be?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 06-24-2013, 12:50 PM   #2
dznf0g's Avatar
Oswego , Illinois
Aerospace 303. I applied once in 2010 and they still open easily from the inside.
-Rich-
Old 06-24-2013, 01:51 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Ours were troublesome too. After getting them open I cleaned them and sprayed silicone on them. They open freely since then.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-24-2013, 02:46 PM   #4
2013 20' Flying Cloud
Cream Ridge , New Jersey
I use Dupont Teflon silicone lubricant. It comes in a four ounce bottle. It is available at Lowe's. Just clean and dry the rubber gasket, put some of the silicone lube on a paper towel and wipe on the rubber all the way around the window. Haven't had any sticking problems since. Safe for rubber and no overspray.
Joe Palmieri is offline   Reply With Quote
Old 06-24-2013, 02:57 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Tire talc is cheap and readily available and works great. It's what I used and I've only had to apply it once.
I've heard that the teflon products work too.
Old 06-24-2013, 03:01 PM   #6
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
The teflon/sicilcone spray seems to stay in place very well. I use it on the rubber seals in my car as well.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
