03-28-2017, 07:26 PM
2009 27' FB International
Murfreesboro
, Tennessee
Wind tore awning at seam--repair?
Last night while we were gone, a storm shot across the lake out of nowhere. I pulled up at just the right time and got our awnings closed, but the smaller one on the side opposite the door whipped and ripped along about 25%. How in the world would I repair?
First time I forgot to put awnings away! Could have been worse!
03-28-2017, 07:41 PM
Oswego
That thin strip of fabric with twin beads is available from zip dee. The entire awning roll must be removed to slide in a new strip. Study up on how to remove the awning safely, as the roll is under spring tension. Best to do this with 2 people.
-Rich-
03-28-2017, 07:43 PM
Oswego
It is common for this strip to deteriorate over time, as it is expose to the elements and sunlight.
Probably time to replace them all as a preventative measure. If one is weak, the rest are too.
-Rich-
Murfreesboro
, Tennessee
Thanks so much! Would this most likely mean the entire fabric of the awning will have to be replaced? Wasn't sure if it's one piece design.
03-28-2017, 07:45 PM
Oswego
Probably not, as the rest of the fabric is protected by the metal cover when rolled up.
-Rich-
03-28-2017, 07:46 PM
Murfreesboro
, Tennessee
Ah. Ok. I hadn't inspected closely yet, as I wanted to let it rest some today. Ha!
03-28-2017, 07:47 PM
Oswego
Zip dee has repair instructions on their website.
-Rich-
03-28-2017, 07:49 PM
Murfreesboro
, Tennessee
Thank you so very much for taking this time!
Oswego
No problem!
-Rich-
03-28-2017, 10:34 PM
1995 25' Excella
xxxxx
, xxxxxx
Check the awning seams. At the 20 year mark, the threads in my awnings seams were rotten. The fabric was solid. I had to have it restitched.
03-29-2017, 06:47 AM
Oswego
OP's trailer is a 2009....so I doubt the seams are rotten, unless the awning has been deployed an inordinate amount of time. However, his experience with the connector section makes me suspicious of my 2007, which has been outside most of its life.
-Rich-
03-29-2017, 06:56 AM
Murfreesboro
, Tennessee
03-29-2017, 07:03 AM
1995 25' Excella
xxxxx
, xxxxxx
FWIW.... The strip is called Flex Key
03-29-2017, 07:13 AM
Murfreesboro
, Tennessee
Thanks SO much.
Murfreesboro
, Tennessee
So relieved it's not a full replacement! Thank you Lord!
04-14-2017, 12:15 PM
1999 34' Excella
Hillsboro
I just received a new 'flex key' from ZipDee for our street side awning which tore. Thankfully, we do not expect more damage.
ZipDee sends the replacement promptly. You will need the width and length of the Flex Key... then ring them up..
I will do ours after Easter... If possible, I will video the process... at least the steps, not all the fussing and beer drinking....
Peace and Blessings..
Channing
WBCCI# 30676
11-03-2017, 06:24 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Channing,
Did you make the video of the flex key replacement?
I rolled out my longest curb side awning this afternoon. The 2" cloth part is ripped at one end and has a hole near the center of the awning. The hole is large enough that a tree frog moved in
Looks like replacement is going to happen soon.
Any advice/instruction would be appreciated!
Thanks!
Alan
