Old 03-18-2013, 07:28 AM   #1
ILOVESALLY's Avatar
2007 25' Safari SS SE
Sarasota , Florida
Why is my trailer so noisy
Im new to Airstreams and looking for your knowledge. We picked up our 2007 SS 25ft Safari a week or so ago. After taking it on a week trip to the FL Keys I noticed that it was quite noisy as we pulled out of the campsite. It seems like when i'm going slow or turning slightly. The noise seems like a long loud withdrawn creaky door sound somewhere as we start to move. I don't hear it when where up and running down the highway. Is this normal?
ILOVESALLY is offline   Reply With Quote
Old 03-18-2013, 07:32 AM   #2
dznf0g's Avatar
Oswego , Illinois
Sounds like the hitch. It is common and normal. There are some methods to reduce the noise, dependent upon brand. What hitch setup do you have?
-Rich-
Old 03-18-2013, 07:38 AM   #3
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
First off, congrats on your new (to you) Airstream!
If you havent repacked you wheel bearings, that might be a good place to start. It is a general maintenance item that should be done on a regular basis anyway. If the noise is coming from the wheels I would certainly take some time to pull the wheels off and inspect everything.
I have noticed that at slow speeds my hitch will creak and groan sometimes. you can check there as well. adding some grease or lubricant to the ball/tongue can help with that.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 03-18-2013, 07:45 AM   #4
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
It could very well be your sway control bar if so equipped. Depending on hitch type I would:
1) grease the ball
2) grease the trunion arms or bars
DO NOT APPLY ANY TYPE of lubricant to the friction sway control if so equiped. It will render your sway control USELESS!
Welcome to the forums!
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 03-18-2013, 07:52 AM   #5
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
Our hitch makes some interesting noises at slow speeds or when turning. It reminds me of the Titanic sinking.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 03-18-2013, 07:54 AM   #6
ILOVESALLY's Avatar
Sarasota , Florida
E2 hitch by Fastway. Just read the trouble shoot in manual. It did say some noise is normal until hitch is broken in and general consequence of positive sway control and moving parts of hitch. Oh well, I guess i will just have to use my trailer lots more and see what happens
Thanks for your help.
Old 03-18-2013, 08:13 AM   #7
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
I guess it is true-when all else fails....read the book
Glad you were able to find resolution . Some grease as mentioned before will help.
Bruce
Old 03-18-2013, 08:19 AM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Yep it's your hitch. I have a Equal-i-zer brand it creaks, pops and groans at low speed. Very typical. According to the manufacturer I could use a small amount of lube but for all intents its job is to provide friction. The best advice is to keep it clean, and lube the ball on your hitch to prevent excessive wear.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-18-2013, 12:46 PM   #9
ILOVESALLY's Avatar
Sarasota , Florida
Thanks all for you help and advice. So over the moon with my purchase.
LoveSally
Old 03-18-2013, 01:04 PM   #10
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Very ominous sounding!!!!
We switched to a ProPride from an Equalizer and have no longer got the "slow speed groan".
Bruce
Barely getting by, towing our 16' Bambi with our Ram 2500 CTD "Moby"!
Bruce B is offline   Reply With Quote
Old 03-18-2013, 01:52 PM   #11
bganso's Avatar
1994 30' Excella
Truckee , California
Were you there?
bganso is offline   Reply With Quote
Old 03-18-2013, 02:27 PM   #12
dkrug's Avatar
Bad Axe , Michigan
Originally Posted by bganso View Post
Were you there?
Nope, just saw the movie
1947 Spartan Manor
Old 10-14-2013, 08:31 AM   #13
Airstream fanatic
Grapes's Avatar
Bouse , Arizona
Mine does the same Titanic thing!!! Its like "eiiirrrrrrrrrrkkkkkkkkkk" haahaa
Cass
1979 Sovereign International (Olivia)
1986 F-250 4X4 (Oscar)
BLOG: http://grapesbigadventure.wordpress.com.
Grapes is offline   Reply With Quote
Old 10-14-2013, 10:37 AM   #14
28Argosy's Avatar
1976 Argosy 28
Marshall , Virginia
LOL Love the Titanic references in sound.
What I would have said has been previously mentioned on lubrication on the hitch ball etc.
1976 Argosy 28'
28Argosy is offline   Reply With Quote
