Old 05-07-2011, 08:09 PM   #1
2010 16' International
kittery , Maine
Why is my burner in galley separating from countertop?
My burner "platform" is separating from the countertop in one corner. Never saw this before but it's possible it came this way from the factory. Regardless, what do I do to fix it? Can it be taken apart from the top, or do I need to remove the fridge unit underneath and access it from the bottom? There's nothing loose or flexible -- everything is very rigid, and it doesn't appear warped -- just looks like something isn't seated properly. It's coming up about 1/8 to 1/4 inch above the countertop in one corner. Other corners are seated all the way down.
Airstream is 2011 16' International new in fall 2010.
Burner is "Princess" 2-burner unit
Photo at i53.tinypic.com/ofdkee.jpg:
amm3824 is offline   Reply With Quote
Old 05-07-2011, 08:42 PM   #2
Ottawa , ON
You got a screw loose I would guess. The cooker's mounting that is.
Looks like it's time to use some of that warrantee service!
Old 05-07-2011, 09:04 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, on my trailer [different model] you lift the edge closest to you/aisle and slide a bit toward you to get to things underneath. The screw or pin that guides it into place may be off or missing.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
bambi, burner, princess, quality
Vintage Fusion - the story of our '69 AS Remodel monah 1959-69 Tradewind 255 09-08-2011 10:40 AM
Stove burner replacement? Lucy98 Stoves, Ovens & Microwaves 0 05-01-2011 07:49 AM
stove burner Lucy98 Stoves, Ovens & Microwaves 0 04-25-2011 03:29 PM
Suburban NT35 Burner adjustment texascanuk Furnaces, Heaters, Fireplaces & Air Conditioning 9 02-12-2011 06:46 AM
