Old 03-08-2016, 11:12 AM   #15
Surf City , New Jersey
dead bolt not working
My situation is the dead bolt.
I have to really push in hard on the door itself for the deadbolt to align
Any ideas?
weber.roger is offline   Reply With Quote
Old 03-08-2016, 11:13 AM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Most important, lubricate the latch mechanism and contacts often and be sure the stabilizers or parking position are not twisting the trailer. When you back into a spot, then pull ahead a foot or so to take any twist out of the tires that puts tension on the trailer and tongue jack. Try to park level. When you close the door, don't just flip it hard; put your hand flat over the latch and follow it closed firmly. The rubber seals will settle in position on a new trailer after some time.
Then look into adjusting (bending) the door, if needed.
Doug and Cheryl
Old 03-08-2016, 11:18 AM   #17
dkottum's Avatar
Any ideas?
Someone may have tried to close the door with the dead bolt out, and knocked it out of alignment. Grab the deadbolt with a needle nose pliers and push gently towards the trailer, maybe it will go back where it should be. Keep it lubed.
Doug and Cheryl
Old 03-08-2016, 11:18 AM   #18
Grapesky's Avatar
2016 16' Sport
Port Saint Lucie , Florida
Originally Posted by mojo View Post
Google is the best source....
looks like he's still slamming the door to close it after all his adjustments
Grapesky is offline   Reply With Quote
Old 03-08-2016, 11:36 AM   #19
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Had the same problem when we got ours, took to dealer and they show me a trick, Always make sure your screen door lock into place, if not it will bounce the door back and also get the screen out of whack.
No problem now, its like my wife been telling me for 45yrs, be genital and it will come around.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 03-08-2016, 11:46 AM   #20
Tom T
Tom_T's Avatar
Orange , California
Originally Posted by MOS View Post
Thanks , now I understand it !
I will have the dealer make the adjustments!
Do not mess with it yourself as many above are saying.
It's a brand new 2016 & so should be under warranty. Have them work on it so you don't void your new trailer warranty. After it's fixed - ask what they did & have them show you, in case it happens again out on the road or after warranty.
Also, never slam doors in trailers, cars, homes, etc. It's usually caused by the door being hung out of square/out of level &/or not properly aligned. If it happens after warranty, fix it - don't slam it.
Yours happened at the factory or on the lot thereafter - unless it was okay when you first picked it up.
Good Luck!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 03-08-2016, 02:16 PM   #21
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup.. dealer time.... go drink a bunch of their 'free coffee'... if you have kids, feed them lots of sugar as soon as you get to the waiting room....may expedite things...
On our 1999 34' the door was 'hard' to close. Obviously I can't claim a "warranty" on the manufacturer... so, once I was sure the door was snug, I adjusted the 'latch pin' on AS frame... now the door just 'clicks' closed...
Also, I have replaced the gaskets...recently.. so, it was easy to check 'seal'...
So, yeah.. dealer visit...
as for the 'Security latch slide'... dealer can resolve.. if not, open a thread...
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-08-2016, 02:47 PM   #22
munimula's Avatar
1993 34' Excella
1962 16' Bambi
New Haven , Connecticut
i have been in the habit of holding the latch in the open position and closing the door firmly. once seated i release the latch and the door is securely shut. and i can do it one handed! no undue force put on the door frame with this technique. been doing it this way for ten+ years now. as other have suggested, lubricating the works helps.
Morrison's Airstream Page
munimula is offline   Reply With Quote
Old 03-08-2016, 03:06 PM   #23
2015 28' International
Washington , Pennsylvania
We have a 2015 International and found the same thing. But I discovered that when closing from the inside, if I pull the handle that is centered on the door, rather than pulling where it latches, it closes much easier. And from the outside, I push it in approximately the same spot as the inside handle is located. Easy fix. Hope it works.
FranM is offline   Reply With Quote
Old 03-08-2016, 03:46 PM   #24
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If you ever get a chance to go to Jackson Center...
Or to Colonial...
They can adjust the door for you under warranty.
Making sure the trailer is level helps- with torpedo level in door sill/threshold.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-08-2016, 04:34 PM   #25
2016 22' Sport
Glenville , New York
I have a 2016 28W just a week old . Closing the entry door is difficult .
Have to slam it and several tries sometimes.
So what is with the door ? Is that the way they are ? Are we doing something wrong ?
Is there an adjustment or fix for it ?
Thanks, Mike
I had the same problem, had to take it back to the dealer. They made adjustments, now just a firm push. A word of caution .... check your outside skin carefully all around for any outside damage that was not there before. When in my dealers care damage was done, still 4 weeks later waiting for promised compensation(check). Good luck
jcole is offline   Reply With Quote
Old 03-08-2016, 06:04 PM   #26
1970 25' Tradewind
anderson , South carolina
Thanks, Mike
Just had the same experience with my 1970 Tradewind ,hard to shut door. As
One of the other replay door need lubrication. Spray pub in all parts and coat
All contact surfaces with bearing grease. Should be no more problem. Bob Cooke
Bob Cooke is offline   Reply With Quote
Old 03-08-2016, 06:56 PM   #27
Sioux Falls , South Dakota
I had that same problem on our mpg when we first got it. I tried using the stabilizers as levelers (NO, don't to that) and the door wouldn't close properly. Took the load off of the stabilizers and the door worked fine. Lesson learned.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 03-08-2016, 07:20 PM   #28
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Originally Posted by idroba View Post
When my 2014 was brand new, it took some real effort to close the door. The rubber seals take time to compress and take a set. That said, I was still unhappy after a month or so, and my dealer was able to make an adjustment so it closes much better now. So, maybe give it some time, but then see the dealer.
Same here. tough to close but also very hard to deadbolt...close hard...firm pop with palm...deadbolt works,
Then on afternoon I noticed what I would consider a sizable gap in the bottom of the jam....daylight for sure, but I prefer the sunset thru the window. I recent had it into the dealer for replacement of the Fwd LP drains and mentioned it. Not sure what they did, but the gap is gone and the DB is smooth as silk.
Talk to your dealer
Name:	IMG_7794 (Small).JPG
CruizinDux is offline   Reply With Quote
Have to Slam the Door on a New AS? ltorgy Windows, Doors, Locks & Vents 53 04-26-2017 08:09 PM
Slam door to lock? john4170 Doors & Locks 24 04-24-2014 11:16 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
