Old 07-03-2016, 05:05 PM   #1
2016 26' Flying Cloud
Southlake , Texas
Who said it would take an hour??
I just spent the afternoon (in 100 deg weather) applying Corrosion-X to all the rivets and exposed edges on the exterior of our 26u. I didn't do the roof or the rivets on the window frames. I also coated all the lights and wheelwell trim. I do have a lot of filaform on the outside grab handle. I can now see why filaform corrosion can be an issue. Probably 10-20% of the rivets have a little damage to the coating around the rivet. Hopefully, my proactive treatment will minimize future problems.
Now that I have done this, how often should it be repeated?
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 07-03-2016, 06:17 PM   #2
LilBigfoot's Avatar
London , Ontario
What was your procedure for coating the rivets and exposed edges with Corrosion-x? Thanks.
You're a long time underground!
LilBigfoot is offline   Reply With Quote
Old 07-03-2016, 06:28 PM   #3
Southlake , Texas
I sprayed the Corrosion-X in the cap and used a Q-tip. Went all the way around the trailer and then wiped off the excess with a towel.
Equalizer Hitch
Southlake, TX
WBCCI
Old 07-03-2016, 07:35 PM   #4
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
How many times did you thank AS for giving you all their uncoated cut surfaces to treat by hand?
TheCabin is offline   Reply With Quote
Old 07-03-2016, 09:50 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
For the uncoated panel edges I took a felt tip acrylic touchup pen and run it carefully along the edge. Let it dry and again for three coats. Use the sharpest tip of the pen so maybe there is a 1/16 inch overlap on each panel side. I think that protects the edge fairly well.
Using CorrosionX and Boeshield T9 we are going on five years and no corrosion anywhere on our Airstream. However we have not exposed it to northern road salt or coastal salt air. We have been applying the protection a couple of times a year now, would be more often in salt environment, less in the desert.
Doug and Cheryl
Old 07-04-2016, 06:32 AM   #6
TheCabin's Avatar
The tip is very important. I found that the tip on the pen from the AS store was too big. When I used it on test plates for a filiform corrosion test it left too much coating that resulted in a noticeable film that I am sure would look terrible on an AS. But again, being required to do this is another example of the low AS manufacturing quality. Our AS may look great, but as all, beauty is skin deep and in this case, a very thin skin that we don't want to break.
Old 07-04-2016, 01:20 PM   #7
Anna Maria , Florida
That was my question as well. I haven't done ours yet because it is a real chore to crawl all over a 30' Airstream. I believe one post said less than an hour.
I still believe this treatment should be applied in some permanent fashion at the factory before the Trailer is put on the street. Looking at the average age of the Air streamers at the Farmington Rally last year tells me that most Airstreams do not get corrosion treatment.
franklyfrank is offline   Reply With Quote
Old 07-05-2016, 06:35 AM   #8
2016 25' Flying Cloud
Holly Springs , Mississippi
Originally Posted by franklyfrank View Post
I still believe this treatment should be applied in some permanent fashion at the factory...
I look at this issue from my half century involvement with aviation. Aircraft manufacturers' solution to this corrosion issue is the use of Alclad panels, and paint, as in painting the entire aircraft. Even then if not well-prepared, usually with an alodine solution and wash before the paint is applied, filiform corrosion can be experienced.
So Airstream's solution is to use pre-coated aluminum sheets and hope for the best on the cut edges and drilled holes. Applying a fine line of clear paint sealant to the cut edges is time-consuming and something I suspect the Factory isn't willing to do. And then, what about the rivets?
So I use Corrosion X. I sprayed every rivet head and panel edge below the roof, let it soak in for a half-hour, then wiped off the excess with a cloth rag. It took about an hour, but I also didn't do the window frames. I believe the window frames, since they are unpainted, are unlikely to get filiform corrosion. (Filiform corrosion runs under something, usually paint. These windows still should be watched because, since they are unprotected, surface corrosion is a risk.)
Someone asked how often to re-treat? Corrosion X is widely used in aviation to spray the untreated interior of wings and fuselages, particularly if not painted with a corrosion preventative such as zinc chromate or its follow-on chromate-free product. Once a year, or even less frequently in non-coastal areas, seems to work quite well. So there's no one answer to the "how often?" question. If you live in a corrosive coastal area, or camp fairly frequently on the coast (including 100 miles inland), or you drive on salted roads, I'd re-treat every year. If you're in Arizona or the mid-West, probably longer will work. Also, if you're a frequent washer, I'd re-treat more often because soap does remove Corrosion X (except where it has crept between the aluminum panels and under rivet heads).
Since it's not a big time-consumer to re-treat, I plan to do it every year here in North Mississippi. After all, it takes less time to re-treat than it does to wash.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 07-05-2016, 06:55 AM   #9
dkottum's Avatar
Bob, very good post.
I had a career in maintenance of Navy aircraft. Our aircraft were painted, but regularly exposed to salt environment onboard ship and Naval Air Stations near the coast. .
One of my early jobs as a young sailor was helping the metalsmiths grind corrosion off the areas where rivets and fasteners held the aluminum panels. It was routine and ongoing periodic maintenance, never ended. Many of those aircraft are now stored (unused for the time being) in the desert of southern Arizona where corrosion is not an issue
Corrosion prevention and maintenance is part of owning aluminum airplanes and Airstreams. The prevention is a lot easier than the repairs.
Doug and Cheryl
Old 07-05-2016, 07:26 AM   #10
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Does this corrosion prevention last longer than waxing? Its it best applied in the shade? I don't think mine has ever had this applied. I see some corrosion on one of the wheel rims but the body seems OK.
Kelvin
Old 07-05-2016, 07:40 AM   #11
dkottum's Avatar
Personally I don't consider waxing corrosion protection. Especially for the rivet holes under the rivets where the wax cannot reach. As for the few panel edges on later Airstreams, I like the acrylic touchup pen application. Easy to do, seals the edge, and I have never noticed the fine line it leaves since I put it on.
Doug and Cheryl
Old 07-05-2016, 08:13 AM   #12
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I've wondered for some time now whether simple clear nail polish might do the trick. Comes with a nice little brush, too!
Lynn
WBCCI 21043
Old 07-05-2016, 03:56 PM   #13
TheCabin's Avatar
This reminds me of my youth when a friend who was able to do pinstriping of cars freehand.
Do you do any special prep to the metal to make sure that the coating sticks to the metal?
Thanks.
Old 07-05-2016, 10:27 PM   #14
Southlake , Texas
If I decide to do the acrylic pen along the edges, how do I remove the Corrosion-X that I just applied?
Equalizer Hitch
Southlake, TX
WBCCI
Dealer said "Typo" on bi-fold oven cvr. RivetED Our Community 64 10-05-2010 05:04 AM
Slate of WBCCI Officers for 2006-7 What if we said "NO" rgesch WBCCI Forum 26 04-11-2006 03:13 PM
Newbie, and I said I wouldn't buy sight unseen. Wexus Member Introductions 27 03-10-2006 01:11 PM
It's been said... 53flyingcloud Off Topic Forum 11 11-01-2003 06:54 PM
