Old 01-25-2015, 04:52 PM   #1
1965 22' Safari
Asheville , North Carolina
White goop sealant...
I recently had a fantastic fan intalled in my '65 Safari. I never asked how the exterior trim ring would be installed....assumed that it would be sealed and riveted. Instead this is what i got. Appears that the plastic trim was screwed in and this junk was poured all around to seal the unit. No question it is water tight but IMO looks pretty bad. Anyone have any comments about this? Is there a better way...more in line with the traditional way fan shroud should look?
jjkitt is offline   Reply With Quote
Old 01-25-2015, 05:08 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Looks just like mine. Must be a couple of tubes used to seal my front fan.
MICHAEL
Old 01-25-2015, 05:17 PM   #3
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
Had my second FF installed (very capably) at the (old) factory. It looks like that and works fine. I only see it once or twice a year.
Follow us at two bikes + an Airstream. Http://Airgo.blogspot.com
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 01-25-2015, 05:29 PM   #4
ottawa (greely) , Ontario
Looks like my factory roof cawlking job !
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 01-25-2015, 07:55 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The installation is done this way because it is easy. It would only take an additional 5 minutes to mask it off and do it properly. Just because a technician does this kind of work as a profession does not mean that they are a professional.
Old 01-25-2015, 08:28 PM   #6
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Seems to be an RV standard installation using Dicor or Sikaflex self leveling sealant or something similar. Looks just like all the vents on top on my Airstream. It won't leak...at least for several years. The only time I see mine is when I wash the roof, or look out a second story window.
There is a product called Eternabond, kind of like a tape, that comes in gray that can be used around vents but I cannot attest to it's effectiveness at stopping leaks as I haven't used it. Here is a link to a video showing how it's used. The part showing it used on vents starts at about the 2:50 mark.
Maybe you can apply this over the Dicor to make it look better.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-25-2015, 08:32 PM   #7
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I can attest to the effectiveness of the Eternabond tape. I used their Alumibond on the roof of our Avion. Great stuff!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-26-2015, 05:33 AM   #8
1965 22' Safari
Well thanks for the comments. I suppose you do not really see the roof too often. My only concern now is how it will look when I run my polisher up to it. Suppose it will turn dark gray or blackish when the pad rubs over it. Oh well...
Old 01-26-2015, 08:32 AM   #9
AWCHIEF's Avatar
Images: 33
Modern Airstreams have a white painted roof. I believe it is for cooling. The caulking blends in pretty well with the paint.
MICHAEL
Goop on tank connections CA_Tallguy Waste Systems, Tanks & Totes 5 08-29-2013 05:36 PM
This goop does what? Alcoa Roller Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-22-2012 02:18 PM
Solvent for the white GOOP AS uses perryg114 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-22-2012 06:24 AM
Propane goop and keeping fridge going during travel hshovic LP Gas, Piping, Tanks & Regulators 7 03-10-2010 08:35 PM
Using Goop? & gaskets stellablu Our Community 4 09-07-2003 08:32 AM
