Old 11-16-2015, 09:36 AM   #15
1974 Argosy 20
Kooskia , Idaho
Originally Posted by DryFly View Post
I had to replace the rims last year - the PO put some nice aluminum ones on with the wrong offset and they rubbed (not good). I took the trailer to Les Schwab to get new rims and asked if they could install 16" rims and I would buy new tires. The guy said it wasn't an option - not enough room in the wheel well. I questioned him but he was pretty adamant.
Did I give up too easily?
More importantly, are you getting any snow?
Mine did fit with no issues at all. I had the axle replaced prior to the wheel and tire change.
No snow yet. Lots of rain.
I will PM you, and send a photo so as not to clutter this thread up more.
Old 11-16-2015, 10:21 AM   #16
Agent 86
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My setup works great for me. New axles with drums, 15" wheels with Yokohama LT tires, and Hensley hitch.
I pull with a half ton regular cab shortbox or a Tahoe. It is rock solid at highway speeds.
Brevi tempore!
J. Morgan is online now   Reply With Quote
Old 11-16-2015, 10:40 AM   #17
ericpeltier's Avatar
Superior , Colorado
My research has told me that disk brakes are really only "necessary" for really heavy trailers. Does any Airstream qualify as really heavy? Probably not. Go for drums, save the $, reduce the complexity.
Also, I tow in the mountains extensively. Drums have been fine for that.
Just my $0.02.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 11-16-2015, 11:12 AM   #18
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
If I were in your shoes:
- Axles - go drum brakes for now and save a few. Several years down the road you can still upgrade the same axles with disk brakes.
- Hitch - get the Hensley. They are not hard to rebuild. If you can grease a wheel bearing you can rebuild this hitch. There are a few wear items to watch out for. While rebuilding look for cracked welds. A local welder can fix this easily. PM me for details if you want. Stinger height can be one area where it could cost you some money to get the correct one. Don't change the stinger out until you upgrade the axles as the trailer height will change.
- I would stick with 15" tires but purchase a high quality tire in the size of 235/75/15 with the XL rating with the size/weight trailer you have.
These items will get you safely down the road for along time.
Take any extra money to replace flexible propane lines, propane regulator, caulking, window and door gaskets.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-16-2015, 11:46 AM   #19
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
As long as the drum brakes are in good condition and working correctly I would not worry about upgraidng to disks. Keep in mind going is optional stopping is not.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 11-16-2015, 01:14 PM   #20
gecko's Avatar
2009 28' International
Pacific Palisades , California
If your axles are OK, leave them. If they're iffy, that's the first thing to replace. Drum brakes are just fine, so if your axles are fine, you can spend zero $$ so far--just make sure your pads don't need replacing--relatively inexpensive.
Lubricate your wheel bearings at least every 10K miles.
If you do need new tires, 16" wheels with Michelin tires are reputed to be way more durable than 15" options. After several blowouts, we just upgraded to 16" all around. The wheels are relatively inexpensive as compared to the tires, but the 16" Michelins are not inexpensive!
We use an Equlizr 4 pt WD and really like it. Standard Reese hitches are also fine. Hensley and ProPride are supposed to be terrific, but they are pricey and weigh a lot, too.
Have fun!
gecko is offline   Reply With Quote
Old 11-16-2015, 01:29 PM   #21
1967 26' Overlander
Spartanburg , South Carolina
Originally Posted by bjmckernan View Post
Go easy on me. I'm a newcomer who has spent enough hours reading threads here to know that asking anything relating to hitches, brakes, 15 vs. 16 this, etc. can lead to craaziness, and that is not my intention
My husband and I just purchased a 1967 Overlander, and I was all ready to snap up fun things such as a Hensley Arrow hitch (from Craigslist), new torsion axles with 12" disc brakes, new 16" wheels and tires, centramatics, TPMS, etc., etc. But...that all gets expensive very fast when I'm working on some other things as well (batteries, fridge, furnace, probably h/w heater, + + +).
So, if I had to prioritize?
I was all set on disc brakes, but just got the axle quote back from Colin, and it was all a little bit higher than I had hoped (without would be $1190 for the axles plus $270 shipping, and with the disc brakes would be $1500 plus $270 shipping, plus I'd also need a $700-$800 actuator)... which makes sense, I'm just having second thoughts now. And we'll be attempting to DIY all of this (I haven't even had a chance to check the axles yet, but assuming it'll be needing them).
I found a Hensley arrow on Craigslist for $1K. Should I forgo that I favor of disc brakes? (I think I can get a Reese pro series or eaz -lift, etc on CL for under $300... Maybe a Reese dual cam for $225 but w/wrong bars).
I'm also hoping to switch to 16" wheels and tires. This seems the easiest to nix to save a little money, but since we have to get new tires anyway, I don't think it'll be that huge of an extra expense. Then there's centramatics, TPMS, and other things that I think are great ideas, BUT add up fast.
Details on how we're using it...We'll generally be towing with a Toyota Tundra (if that matters). Not full-timing, just looking to take the kids camping as much as we're able. Slowly fixing it up over time if we love it...
SO, if you had to rank such things from most impactful to least, in your airstreaming experience, how would they shake out?
I'd love to try to get the biggest bang for our buck here. I want it to function well, but in order for us to even be able to enjoy it, I need money left over to make the inside comfortable and functional since we'll be spending more time camping in it then driving it...
Thanks in advance!
Bonnie
Seems to me "Protagonist" is right about prioritizing. Having done that, explore some options on each item. I have towed a '67 Overlander many miles over 25 years and will be installing new axles before long. I use the KISS method on most things and having had very good experience with electric drum brakes will stay with them when I put on new axles. Colin's axles for the Overlander have 10"brakes instead of the original 12". Experts I have spoken with say that reduces the braking efficiency of the drums an estimated 10 to 20%. Having had two TV brake failures, both times stopping with only trailer brakes, I want to keep my 12" brakes. Andy at Inland RV quoted Dexter axles for my trailer with the larger brakes. It would be worth your while to call him for his take on the subject.
Jacob D is offline   Reply With Quote
Old 11-16-2015, 05:27 PM   #22
bjmckernan's Avatar
1967 26' Overlander
1974 Argosy 26
Charlotte , North Carolina
Looks like that includes 12" brakes...
Great point on the 10 vs 12.
You got me thinking, so I pulled up the details from Colin and it sounds like I should be good to go, right? I agree with you on the 12" for sure...
"The axles will come completely assembled & include 12" brakes, powder coated axle tubes, "safety lube" spindles (allows you to grease the bearings without removing the wheels), shock brackets welded in place, mounting bolts, lug nuts & an owners manual. Please note that the mounting holes will not line up with the original holes, so some minor drilling will be necessary."
QUOTE=Jacob D;1711228]Seems to me "Protagonist" is right about prioritizing. Having done that, explore some options on each item. I have towed a '67 Overlander many miles over 25 years and will be installing new axles before long. I use the KISS method on most things and having had very good experience with electric drum brakes will stay with them when I put on new axles. Colin's axles for the Overlander have 10"brakes instead of the original 12". Experts I have spoken with say that reduces the braking efficiency of the drums an estimated 10 to 20%. Having had two TV brake failures, both times stopping with only trailer brakes, I want to keep my 12" brakes. Andy at Inland RV quoted Dexter axles for my trailer with the larger brakes. It would be worth your while to call him for his take on the subject.[/QUOTE]
bjmckernan is offline   Reply With Quote
Old 11-16-2015, 07:39 PM   #23
"SPACE A"
2006 34' Classic
Fort Worth , Texas
You would like the Hensley/ProPride hitch, disc brakes, 16" wheels, new axles, and Centermatics, much better than the others have suggested. I have towed with all these items for 45 years as they became available to the RV market and they have saved my bacon many times over. Safety, performance, and low to no maintenance are the main reasons for using these items. Call me prejudiced or opinionated, but it is the truth. Why? You can buy a rebuilt and guaranteed hitch from Hensley for a fair price much cheaper than a new one. I have had lots of free replacement parts sent in the past due to extensive towing way up North. Hensley questioned a loose bearing cap and then asked me to send them the whole head. They replaced the head. They said they could not design a hitch that could stand the wear my Classic 35' SOD places on their hitches on those roads. At no time did any failure render the hitch unusable. No problem they said, "It has a lifetime warranty." Disc brakes have about two times the stopping distance as drum brakes, require no maintenance or adjustments. Replacement pads are very inexpensive Chevy aftermarket part store items that last 40,000 miles. The only problem is you need a backup camera to watch for tailgaters as they won't be able to stop in time during an emergency stop. Sixteen inch wheels will allow you to use truck tires for much better tire reliability. New axles are a no brainer if the old ones sag too much. The Centermatics keep the tire, wheel, brake, and hub assemblies in balance no matter what happens short of tire failure. However, if you are going to do the other changes, doing them all at once saves lots of repeat labor and money and you can get everything fitted up right the first time. Enjoy you trailer and hit the road.
guskmg
Old 11-17-2015, 01:56 AM   #24
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
To add to a prior post above, our experience switching from 15" wheels and tires to 16" wheels and tires will alter the elevation of the trailer by about ½" higher with the 16" wheels.
On our upgrade for the 23D, the tire and wheel change raised the trailer a little over 1":
GYM ST215/75R14C rated 1,870 pounds @ 50 psi - 26.7" diameter on factory 14" wheels
Michelin LTX (P) 235/75R15 XL rated 2,183 pounds @ 50 psi derated to 1,985 pounds - 28.9" diameter mounted on 15" SenDel T03-56545T wheels
This change brought the 23D to the same elevation of our prior 25FB so all the Hensley hitch parts worked with the same settings including the CanAm pre-bent stinger for the Mercedes.
The Classic tire upgrade:
GYM ST225/75R15D rated 2,540 pounds @ 65 psi - 28.3" diameter on factory 15" wheels
Michelin LT225/75R16/E LTX M/S2 rated 2,680 pounds @ 80 psi - 29.2" diameter mounted on SenDel T03-66655T 16" wheels.
Old 11-17-2015, 05:16 AM   #25
bjmckernan's Avatar
1967 26' Overlander
1974 Argosy 26
Wow, all of these answers have been incredibly helpful. Thank you all for taking the time to provide your input.
I forgot to add a brake controller to the mix... And of course now I'm all contemplating P3 vs. Direclink (ha, I should probably just stop reading threads).
Luckily, once we deal with the running gear and safety aspects, most of the rest is in pretty decent shape (unlike the argosy we got that will need everything). PO had redone water to pex, upgraded gas and electrical, appliances all work, possibly even added a grey tank (it's been in storage since we got it while I get the argosy ready to sell). If the furnace is original, we'll replace that of course though.
Thanks again for all of the advice. Even with the 100s of threads I've read, you all have really added some clarity and helpful information
Old 11-17-2015, 05:40 AM   #26
switz's Avatar
2014 31' Classic
Images: 8
Another tidbit of knowledge is that with the trailing arm suspension Airstream uses, when a tire hits a bump, it travels up and back. So one must be sure the wheel has zero offset and the correct bolt pattern for the lug bolts in the drum brake or disc brake. The width of the tire must be selected so it will not run against either the plastic wheel well or the outer skin.
For the Airstream environment, the 14" wheels have five bolts on a 4.5" circle with a 3.19" center hole. The 15" wheels are six bolts on a 5.5" circle with a 4.25" center bore. SenDel makes their 16" wheel also with the 15" bolt pattern and their 15" wheel also in the 14" bolt pattern.
I acquired the SenDel wheels though a local Discount Tire store in Mesa, AZ. For reference of the wheel specifications:
http://www.sendelwheel.com/wheels/t03bm
When I arrived to pickup the 23D, we were switching to the 15" wheels and tires from Airstream's stock 14" wheels and tires. The curb front tire rubbed the front metal. Upon measurement, we discovered the the street side wheel well was cut so there was about ½" of metal behind the plastic wheel well. The curb side had about 2" of metal. Obviously the two metal smiths at the factory did not compare notes. We loosened the trim and cut the skin to the same measurement and reattached the trim piece and the 15" tire and wheel fit fine.
The wider width 15" Michelin tires also fit with more than adequate clearance on both the 2015 23D and the 2013 25FB we had before..
Old 11-17-2015, 01:45 PM   #27
1990 32' Excella
jonesboro , Arkansas
Lot of great ideas. Towed 31 and 32 footers to over 100 thousand miles with ez tow WD hitch and hitch to tongue sway bars the desert and mountains with no problems and I used Firestone e rated Lt tires. I never had a blow out or tire separation. Had the tires balanced at the tire store. I can forget to take a coffee cup off the counter and it is still there 300 miles later. For appliances and heaters etc try co law Rv in Carthage mo. New and used and they ship
joel is offline   Reply With Quote
Old 11-22-2015, 07:59 AM   #28
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
My 2-cents, FWIW:
The Overlander is not that heavy that it needs 16" E-rated tires - so my suggestion is to go with Michelin P tires. Stay away from any ST tires.
Get drum brakes with your new axles - they work fine.
Definitely get Centramatics, as that will alleviate the wheel/drum balancing issues.
A TPMS system is good, but checking your pressures manually before starting out and having an IR-type temperature reader (sells for around $30) to check tire temps will do as well. My experience with the TPMS systems is that the only one that provides reliability is the Dill system, which has to be installed when the tires are installed, as they are inside the rim (and are part of the Schrader valve).
As for the hitch, there are other that Hensley/ProPride that will do well. My AS came with the Reese Straight-Line (which is a dual-cam system) that works well for me. The newer models of them are much easier to set up that my 29-year-old one.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Which would you rather own and why? Glamper1 Buyer Guidelines 23 07-20-2015 08:21 AM
I would rather be…? Bruce B Off Topic Forum 11 12-07-2014 12:30 PM
Would rather be working on my A/S funkill Off Topic Forum 6 11-05-2012 09:19 PM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
