Old 05-25-2013, 08:38 AM   #1
1966 17' Caravel
Klamath Falls , Oregon
Which Rivet Gun?
I have a cheap rivet gun and would like to upgrade to a good one. Is there such thing as a "middle of the road" model? I'm not sure that I need the "top of the line" one. Rivets----Where and how do I get the right assortment?
Stefandmissy is offline   Reply With Quote
Old 05-25-2013, 09:06 AM   #2
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Are you looking for a pop rivet gun or a buck rivet gun?
aluminitus is offline   Reply With Quote
Old 05-25-2013, 10:17 AM   #3
There are not that many different size pop rivets that were used on your Airstream.
A decent pop rivet gun kit will come with several different nose pieces so that you can install different diameter rivets, including the Olympic rivets that are used on the outside.
Old 05-25-2013, 10:19 AM   #4
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
For pop rivets I like the Stanley Pro sold a HD.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 05-25-2013, 11:01 AM   #5
1966 17' Caravel
I am not familiar with a buck rivet gun. Can you tell me about them and their price range?
Old 05-25-2013, 11:18 AM   #6
Buck rivet guns can cost several hundreds of dollars.
You must also have a decent air compressor to power the gun.
Also, typically you must use 2 people when your buck riveting, one with the gun on the outside of the trailer, and the other with a bucking bar on the inside of the trailer.
Old 05-25-2013, 11:48 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Never heard of a buck rivet gun, either. But as far as which pop rivet gun to buy? My belief is that you should always buy the best tool you can afford. Where tools are concerned, cheaper is not usually as good a quality, and the more expensive ones will give longer and better service.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-25-2013, 12:37 PM   #8
1966 17' Caravel
Andy, So what would one have to pay for the decent rivet gun plus rivets that you described?
Old 05-25-2013, 12:42 PM   #9
toastie's Avatar
1955 22' Safari
Great Lake State , .
The $129.00 one works great, bought mine on sale for $99.00
toastie
Aircraft Tool Supply | ATS ECONOMY RIVET GUN | 2602A
Aircraft Tool Supply | Rivet Guns Page 1 of 5
toastie is offline   Reply With Quote
Old 05-25-2013, 01:28 PM   #10
Less than $ 45.00.
The rivet cost depends on what all you wish to have.
Old 05-25-2013, 02:27 PM   #11
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Airstream sells rivet guns and rivets on their website. A middle of the road gun for $39 and a kit with a high end gun and and assortment of rivets for $158. You can pick the rivets you need and get them in small packs. Sure, there are other places you might save a few bucks if you know what you are doing, but the Airstream site is not a bad place to buy. Home Depot and Lowes sell fairly good rivet guns.
Old 05-25-2013, 02:38 PM   #12
1976 31' Sovereign
Oswego , Illinois
I have had marson model ma39001 pop riviter since 1976, cast alum. wide range of nose pcs. std. zipdee uses the same as mine they are commercial qual. never a probl. Rivets can be pur big box store hrdw. etc. some A.S. have colored pop rivets, white at any place
Old 05-25-2013, 03:15 PM   #13
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
So, there is no easier way to get a buck rivet than a compressor, an air driven riveter and an extra pair of hands? I need to replace some rivets around our door that have to be low profile, the originals I guess are buck rivets.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 05-26-2013, 07:40 AM   #14
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Sounds like you need a buck rivet gun for the rivets around the door. Buck rivets have a smooth head and are used for exterior applications whereas pop rivets wind up having a hole in the middle, leak, and produce a funny looking stumpy bit on the back side. They are appropriate for interior use or where water-tightness is not an issue. There are other kinds of pop rivets, but I don't think they are what you need. Maybe there is a tool rental place near you where you can get one for a few hours. You will need a bucking bar, air compressor and a friend too.
