Old 05-26-2013, 07:44 AM   #15
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
Also, if you just need a pop rivet gun, you can get an adequate "hand-powered" one for $15-$20 at your local hardware store or on amazon. I did all of my pop riveting with a $15 one and unless you plan on restoring many trailers, it is probably all you will need for pop rivets.
aluminitus is offline   Reply With Quote
Old 05-26-2013, 09:21 AM   #16
lewster's Avatar
Naples, FL , Hood River, OR
Here's my choice: McMaster-Carr
Old 05-26-2013, 09:59 AM   #17
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I use a Marson HP2. I also have one from Home Depot with a swivel head which is handy for some applications. They are both in the $40 range and can take various sized rivets.
The problem with the cheaper pop rivet guns is after a while the jaws loose their grip on the rivet shaft causing it to jam or not work at all.
Old 05-26-2013, 10:14 AM   #18
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Lew, I really like the stockings on yours.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-26-2013, 10:16 AM   #19
1974 Argosy 20
Kooskia , Idaho
I also like the mid priced pop rivet guns with a swivel head as Lumatic suggests. The swivel allows you to get into many more places than a straight head.
That said, I have several pop rivet guns as the size and nose pieces and offset required on each different one usually allow me to find one which will get at that occasional impossible rivet location. One size does not fit all I have found. The really nice big professional ones are great, but too big to fit in a lot of locations. The swivel ones are the best single tool compromise.
Old 05-26-2013, 10:18 AM   #20
lewster's Avatar
Pat
Pat,
I really like where you're going with that comment but those, of course, are rubber hand grips.......
The black case on the left side actually catches the rivet pins after they pop off from the rivet. Keeps things neat and tidy!!!!
Old 05-26-2013, 11:38 AM   #21
The Marston HP2 is a very good pop rivet gun kit.
We have a tough time getting enough of them.
Old 05-26-2013, 01:51 PM   #22
Images: 59
Originally Posted by Globie64 View Post
So, there is no easier way to get a buck rivet than a compressor, an air driven riveter and an extra pair of hands? I need to replace some rivets around our door that have to be low profile, the originals I guess are buck rivets.
Specifically for Globie64, for the rivets around your door you should use a rivet squeezer. Olympic or pop rivets won't work.
If you can touch both the head and tail of the rivet with your thumb and forefinger, then this is the way to go.
And it only requires one person, and no air compressor.
If you only have a few to do, a rivet set and a small hammer can also work in a pinch.
Old 05-27-2013, 02:20 PM   #23
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Thanks Aluminitus, I'll check the rental place. I'm sure I can come up with a compressor and a friend.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
