Old 06-29-2015, 08:54 AM   #1
Springville , Alabama
Which lubricant for stablizing jacks?
I want to lube the screw-section and moving parts of the four jacks, and was wondering what to use. Seems like grease or oil would really pick up the road grit.... any suggestions?
driftwood1 is offline   Reply With Quote
Old 06-29-2015, 09:28 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The written instructions for my Bal light duty stabilizers on my Safari says to "Use WD40 or a similar lubricant". I have given them a shot of WD40 and used a wire brush to clean rust/scale off of them.
Any lubricant that dries completely would work.
Alan
Old 06-29-2015, 09:41 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have always used WD-40 on the stabilizer screw drives also.
Brian
SuEllyn & Brian McCabe
Old 06-29-2015, 09:55 AM   #4
1974 Argosy 20
Kooskia , Idaho
WD 40 about once a season is what I have used for years.
Old 06-29-2015, 10:46 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I just saw this for the first time at HD....worth a try.
Old 06-29-2015, 11:09 AM   #6
grizbear's Avatar
2004 25' Safari
Crestview , Florida
I use axle grease about every two years clean it off with brake cleaner before applying new grease. Spray on oils don't last long. If you have rust something called Corrosion X works great on any rusted or corrosion areas any where on the AS. Good camping Rand
grizbear is offline   Reply With Quote
Old 06-29-2015, 11:37 AM   #7
dznf0g's Avatar
Oswego , Illinois
I use bike chain dry lube.......whatever product you use, make sure it is a dry lube, or you'll have road grit all in the threads.
-Rich-
Old 06-29-2015, 01:12 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Boeshield T9 works well as a lube and a corrosion prevention because it leaves a paraffin wax residue. I spray them during routine inspections along with the other steel parts under the Airstream. Spray the area where the jacks are bolted to the trailer well, this is a common and bad place for corrosion to start.
No corrosion at all under our Airstream after four years and the stabilizers are lubed well. Picks up some dust but that washes off.
Doug and Cheryl
Old 06-30-2015, 10:48 AM   #9
1981 31' Excella Limited
Anchorage , Alaska
I use CorrosionX, which is an aviation Mil-Spec'd dry lube. Available at aviation maintenance stores, or online. Works fantastic for lubing, protecting against rust, and doesn't attract more grime.
1981 Airstream Excella 31'
Wasilla, Alaska
akflyer is offline   Reply With Quote
Old 06-30-2015, 10:52 AM   #10
Plan-B's Avatar
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Watervliet , Michigan
I agree with dznf0g, being a long time dirt bike rider there is nothing better than dirt bike motorcycle chain lube. It has amazing lubrication qualities, doesn't attract dirt and will not drip off. I only have to spray once a season and you are good to go. Stop by a Honda or Yamaha dealer they will have tons of it. You won't be sorry.
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
Old 06-30-2015, 11:35 AM   #11
Thanks for the feedback everyone.
Old 06-30-2015, 11:39 AM   #12
1985 31' Sovereign
Lovettsville , Virginia
Another good option is FluidFilm. Now available at Lowes, usually found at John Deere dealers and snow removal equipment shops. Its natural, non-toxic, a great lubricant and corrosion inhibitor. I use it extensively and am a huge fan of the stuff.
85 Sovereign is offline   Reply With Quote
Old 06-30-2015, 06:58 PM   #13
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I have never seen this in Canada.
MelGoddard is offline   Reply With Quote
What window/door gasket lubricant to use? neil.ervin Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 12-31-2007 09:28 AM
Lubricant 1953 Flying Stoves, Ovens & Microwaves 1 06-29-2007 03:00 PM
h20 compresser lubricant Flyincloud Water Heaters, Filters & Pumps 3 08-23-2004 06:25 AM
Door hinge lubricant paddy79 Doors & Locks 2 07-27-2004 08:45 PM
coconut oil lubricant for drains murphy Waste Systems, Tanks & Totes 9 05-12-2003 08:01 AM
