Old 04-26-2014, 06:57 PM   #57
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Originally Posted by rodsterinfl View Post
Pharmgeek, how many people are I'm your AS at a given time? Your could run either unit and cool that camper. I have done the calculations for btu using two different industry formulas. I learned abut the oven and 3 people limit of my 25' with my 11k unit which is just fine for me with my window area. The pano window models, using the one formula would require a 13,5 unit if three adults were in a 25. Consider this for your AC use. What you do not want is too much AC for a given space. You can probably run on the one 15k unit alone.
I've wondered if running the 13.5k alone would cut it -
30 foot bunkhouse unit - two adults - 1 year old - a 3.5 year old and a boston terrier
The placement of the 13.5 is on far front end but it could in theory work to keep things ok - maybe?
PharmGeek is offline   Reply With Quote
Old 04-26-2014, 08:09 PM   #58
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Just quickly ran the figures on your 30'11" unit and it has 48 sq ft more than a 25' and needs 12,000 on the one formula and 14,379 on the other. In the evening I am sure it would be closer to the lower number. Either way, the bigger AC unit in the middle might be the best choice for figuring generator selection. You could always run the smaller one instead. The little "critters" probably together add up to an adult- so three but your added space makes a difference.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 04-26-2014, 09:01 PM   #59
2006 25' Safari
Images: 8
From what I can tell, when considering AC the higher BTU required formula figures on potentials- oven in the room, people heat, etc. while the other is basically square feet, ceiling height and insulation with ambient temp. IMHO it is a telling range when used together.
As part of a generator thread the choice of AC unit may have been already made and wattage is not too difficult to calculate from amps load. The generator should not be loaded more than 70-75% capacity to run an ac for an evening per se. In most situations a 3000 watt gen will meet the need. In some cases a 2400 as in a 11,000 like mine.
Old 04-26-2014, 11:42 PM   #60
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
this was discussed in another thread, but can a 3000 run the 15K at 75% power? Mine is a dometic 15k....I recall another thread it was said that it would not but im not sure.
I am just researching this for fun for possible purchase next year....for now we have no boondocking plans, but in the near future I will...also, I still have not yet had my 30 or 50amp power installed at home and next year I plan on having family visit and will use the trailer in summer for sleeping....so I suppose if I never bother with the power upgrade for my parking pad, I could just use a gennie for the few times a year company stays....wonder if something like a honda 3000 would be heard by neighbors
Old 04-27-2014, 08:05 AM   #61
2012 25' FB Flying Cloud
Grand Rapids , Michigan
Is there a simple digital battery monitor out there that will indicate the state of charge and fit in the battery box so wiring doesn't need to be run to the trailer interior?
Jwestman is offline   Reply With Quote
Old 04-29-2014, 07:39 AM   #62
2007 27' Safari FB SE
Spokane , Washington
FYI,
Champion has just introduced the new 3100W inverter generator with remote start, the question about remote start came up earlier thought I would update those looking.
3100W Inverter w/ Wireless Remote | SuperGen Products
shaggy1970AS is offline   Reply With Quote
Old 04-29-2014, 08:32 AM   #63
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by mommythrice View Post
Bringing home my '66 Airstream next week, so this is probably on the first of a gazillion questions I will have! We're finally ditching the big, ugly class C RV.
We love to boondock, so I know I'll want a generator at some point. What do I need? I've been looking at the Honda 1000 & 2000 (used, on Craigslist). I want to be able to recharge battery, run fans, water pump & heat, watch a movie on the laptop, coffee pot & hair dryer. It seems like the real issue is A/C. I have no intention of running a generator & A/C 24-7, but it would be nice to turn it on to cool off for a few minutes before bed. If we are driving from Texas to Colorado, we occasionally spend one night in a parking lot on the road and need A/C.
Will the EU1000 do everything I need except A/C?
Could I bring an extra 1000 to run in tandem for A/C when we're camping in the heat? Or will that still not be enough power?
Thanks!
Tracie
Back to the OP questions ...Yes and yes. Be advised that to pair two EU2000i gens you will need the proprietary Honda parallel hook up. However, if one of your gens is the EU2000i COMPANION, you will only need cables to interconnect them (Honda or aftermarket work fine).
Old 04-29-2014, 11:40 AM   #64
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I bought a 2000. I have both the payload and room to carry it. If I was very short on space or payload or lifting power I would try the 1000. The 2000s seem to me a better buy and a little more useful than the 1000's. The Honda and Yamaha 2000's are a nice total package. Easy to handle, quite, do not seem to leak fuel, fairly low noise, nice self contained package.
Old 04-29-2014, 04:19 PM   #65
2006 25' Safari
Images: 8
Pharmgeek said: this was discussed in another thread, but can a 3000 run the 15K at 75% power? Mine is a dometic 15k....I recall another thread it was said that it would not but im not sure.
I am not sure what model your Dometic is but according to the specs on the current Dometic HD, Commercial and Brisk, the compressors all require 13.3 amps and the fan 2.0 or 2.8 amps depending on the model line. So. It sounds like your looking at 16.1 amps at most to run it with fan on high. Dometic calculates at 115V so 1852 watts is the requirement. The next bit is the motor spike or, in this case, the compressor. A 3000 watt has 3000 watts ceiling cap in the case of a spike before shutting down to protect itself. If a load beyond 3000 watts is added gradually it can actually go beyond 3000 watts but it is not good to run any generator at 100%. The Yamaha 3000 SEB model allows for a boost for at least 10 seconds beyond its capacity. In my case, the 2400isHC is similar. The circuit has a capacitive boost (HC- high current) although for a lower wattage requirement than the 3000. You would be fine with a 3000, at least the SEB.
Old 04-29-2014, 04:30 PM   #66
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
That's the model the long long honeymoon folks use - I may check in with them and see how it's still going for them as well
Old 05-01-2014, 09:07 AM   #67
Tadashi's Avatar
2016 22' Sport
2015 Interstate Grand Tour
Odenton , Maryland
Mommythrice, what did you go with?
I was considering two propane/gas/LNG EF2000iS versions from US Carburation hooked in parallel. If I did the calculations right a 20# tank will run one for 17 hrs under full load. So two of these with 2 20# propane tanks will last 17 hrs and provide 36A and 4000W. Also 45 lbs seems easier to move around than some of the 2400+ sizes. The only con I see if cold weather usage may be an issue.
“There are two kinds of travel: first class and with children.” -Robert Benchley
- WBCCI #3750;; CMU #166, 2nd Region
- 2015 Airstream Interstate Grand Tour EXT
- 2016Airstream 22FB Sport
Tadashi is offline   Reply With Quote
Old 05-05-2014, 07:59 AM   #68
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
One factor worth noting if you're trying to decide between a Honda eu2000i and eu3000is - if your TV is a truck with a tonneau cover, you may find that the eu3000is is a little too tall (at 22.4") to fit in the bed of your truck.
This helped me make my decision!
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 05-05-2014, 08:07 AM   #69
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Had not thought of that - need to measure - thanks
Old 05-06-2014, 05:25 AM   #70
Tadashi's Avatar
2016 22' Sport
Odenton , Maryland
The weight (134 lbs) and the heights (23") of the EU3000 made the decision for me as well. I have a F350 with roll-n-lock and the 3000 would not fit in the bed with the cover closed. I finally went with the EU2000i and Companion. I then ordered the propane, gas, LNG conversion for both. I will let you guys know how this turns out. The reason against the Yamahas despite the lighter weight and more quiet operations was the comments seemed to indicate consistent subquality issues over the Honda.
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which generator to buy? nmex Generators & Solar Power 13 04-27-2007 11:38 AM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
