Old 04-26-2014, 08:12 AM   #43
r carl's Avatar
Lin , Ne
Originally Posted by shaggy1970AS View Post
Opinions and information are the only things that are free these days. I am all about getting as much info out there and allowing one to make a smart choice before the money that is so hard to earn these days is gone. Hopefully someone in the Market for a generator will read this thread and realize that other options are available then the red and blue machine. I'lll bet you will see more of the yellow machines at your local camp sites as the word gets out.
I would not recommend a china built machine to anyone at any price.
r carl is online now   Reply With Quote
Old 04-26-2014, 08:33 AM   #44
2007 27' Safari FB SE
Spokane , Washington
Just wondering if you have an iPhone? LMAO
shaggy1970AS is offline   Reply With Quote
Old 04-26-2014, 09:21 AM   #45
r carl's Avatar
Lin , Ne
I have a 7yr old Motorola razr. I buy NOS ones off ebay to use.
Old 04-26-2014, 10:18 AM   #46
1974 Argosy 20
Kooskia , Idaho
If possible, run no alcohol gas in your little engines. Here is a web site which will tell you if you can get it close to you. Ethanol-free gas stations in the U.S. and Canada
Since I started doing that each and every one of my single cylinder engines has run better and has had no carb gumming issues. I do live in a colder climate and gas does not deteriorate as fast here. So, my Honda's, my ATV's, my lawn tractor all start right up in the spring now, and that was not true in the past when I didn't use non alcohol gas in them.
My Honda 3000 got pressed into sudden service the other day when the power here at the house went out. It had not been run in 6 months. I found that by accident I did not even shut the gas off to the carb the last time I used it, and of course never drained it. About 3 seconds of cranking (electric start) and it was off and running, smooth and quiet as usual.
I have no problems with alcohol gas in my modern cars, they were designed and built with it in mind. It is the little carb type engines from another era which seem to be most sensitive to it.
Old 04-26-2014, 10:57 AM   #47
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Interestingly there was another forum member on this topic about a month ago. I will plug again for Yamaha- hands down on anything below a 3000 as their design is superior. What I learned from members on that other thread is that once you get to a Honda 3000 then it is about equal in design between Yamaha and Honda but the Honda is about $300-400 more, no wheels, go figure. I would study the differences if I were you and look also at some others that have been mentioned. Dometic has one now too for less. The issue is parts. I will say that if you go with a smaller generator, go with a Yamaha. There are several differences between them and Honda, on smaller models- fuel gauge, metal engine parts vs. plastic, direct drive versus a belt to name a few. I have an 11K BTU AC Dometic Penguin and a 2400isHC runs it easily while using other things. Your use may be different. Oh, on the parts thread readers, I checked on this after being questioned on the other thread. It is true about the parts on Honda as plastic and the belt driven below the 3000 model. Also mommy thrice, consider a tri-fuel model (on that runs on LP or gasoline) as the #1 issue with generators is clogged carbs from gas. The corn gas doesn't help either. You can DIY tri fuel with a kit or have a dealer do it (warrantied) as I did. Here is a Yammy dealer that tri-fuels the units by order. They have a new patent that makes it easier to do now.
http://www.yamaha-propane-natural-gas-generators.com
Here is the kit link (same company)
A and C Propane Natural Gas Conversion Kits
I know there are some that complained of this company but they were super nice to me, guided me through the adjustment procedure with LP and sent pictures of the fall leaves in WV just because I mentioned missing that in FL from when I was a kid.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 04-26-2014, 11:39 AM   #48
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Which generator for newbie?
I have the 15k AC in middle and 13.5 AC over front bed -
Seems to me the 15k really complicates my decision process for next year's plans for dry camping
I'm near to point if just getting a 1k of some sort and waiting for Santa for it
Any opinions on best setup taking out AC from equation
Someone earlier described their 1k I recall setup and some bit of solar?
Edit: clarify - it's so hot down here I think I have been just thinking about not camping without hookups in the hottest months and plan dry camping for all other 8ish months
PharmGeek is offline   Reply With Quote
Old 04-26-2014, 11:53 AM   #49
2006 25' Safari
Images: 8
@Pharmgeek, I would certainly get one to run your AC. Really, unless you boondock, there is no reason for a generator but you may want that air at some point. Pull your book out on the specs on that AC unit and add the fan and compressor current draw. I looked up the Dometic 15K. It draws 16.1 max. continuous. That draw will dictate the generator. As I just looked before posting above, there is a definite difference in price right now between Yammy and Honda. If your unit is the Dometic 15K then it requires about 1900-2000 watts to run continuous with a startup. A boost model (10 sec/500 watts) should work fine. A 3000 SEB would work for air but not too much else (at once). That would be my choice.
Old 04-26-2014, 12:00 PM   #50
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
I'm with you on the 15,000 BTU AC units complicating things a bit as it looks like one would need a 3000+ unit to run everything. My issue is I have a 9000 watt unit I use as a backup for my house and a 1750 Colman unit that has been sitting in the corner of my shop for years and never used. The issue (for me) is the 9000 is to big to haul around and the 1750 is to small to run everything. As I have a convection over/micro combo instead of the standard gas oven and I'm guessing that will use more juice than the little 1750 can deliver. So even taking the AC unit out of the picture, I'm thinking I still don't have the ability to (not) spend more $$ and buy something....
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 04-26-2014, 02:16 PM   #51
mommythrice's Avatar
1966 28' Ambassador
Lots of great advice. Now I just need to work through it all.
One more question... what do you do to prevent theft?
Would a bicycle lock through the handle of the genny and around an axle or frame work?
mommythrice is offline   Reply With Quote
Old 04-26-2014, 02:37 PM   #52
ottawa (greely) , Ontario
Originally Posted by Wayne&Sam View Post
An advantage to Yamahas are that the off switch cuts off the gas and you can run the carb dry. Not so on a Honda (you have to run the whole tank dry). Saves headaches and gummed up carbs.
The honda generator 1000i and 2000i have a drain for the carb ( bowl ) just pull off the cover and use a normal slot screwdriver on carb bowl unscrew it and fuel will flow out a clear hose to the bottom of case , this I only do if I'm not going to use the generator for some time ,you don't have to drain it every time you use it just if it's going to not be used for 8 weeks or more
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 04-26-2014, 02:42 PM   #53
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes that's true, but it seems more reliable with the fuel cut off on the Yamaha. As in I was going to use it within a month but didn't and forgot to drain the bowl.
My Yamaha also has a bowl drain but it's a little harder to get to than on my Hondas.
Old 04-26-2014, 02:43 PM   #54
Yes you can do that ,if you do a search on internet , I have seen special locks for the honda 2000i can't remember if they were from honda or aftermarket, or you can chain your Rottweiler dog to handle of generator .( ha ha )
Old 04-26-2014, 04:54 PM   #55
2006 25' Safari
Images: 8
Pharmgeek, how many people are I'm your AS at a given time? Your could run either unit and cool that camper. I have done the calculations for btu using two different industry formulas. I learned abut the oven and 3 people limit of my 25' with my 11k unit which is just fine for me with my window area. The pano window models, using the one formula would require a 13,5 unit if three adults were in a 25. Consider this for your AC use. What you do not want is too much AC for a given space. You can probably run on the one 15k unit alone.
Old 04-26-2014, 05:07 PM   #56
2006 25' Safari
Images: 8
They make truck bed locking systems. I bought the lock online then added my own harness.
Yamahas have a petcock valve that makes it easy to run the gen out of gas. For the occasional user I would still recommend LP operation. BTW, the petcock does run the carb out of fuel.
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which generator to buy? nmex Generators & Solar Power 13 04-27-2007 11:38 AM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
