Old 05-23-2016, 07:20 PM   #29
richw46's Avatar
Lexington , Kentucky
Originally Posted by DLMueller View Post
Several years ago I purchased the remaining stock of a local electronic suppliers discontinued 30A 32V slow blow glass fuses. The fuses are labeled 32V 313 30A. I would be glad to sell them for $2 per pack of 5 plus shipping. PM me if interested. I will be bringing any remaining stock to International to sell in the flea market.
That's the Littlefuse brand. You have a good price at $2 for a 5 pack.
I found them at Sears for $2.83, no mention of how many. They show only 1.
http://www.sears.com/littelfuse-313-...-SPM8253778502
Platt has them too, price is $2.29 for a pack of 5
https://www.platt.com/platt-electric...spx?zpid=33881
Amazon has the listing but they are sold out.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-23-2016, 07:21 PM   #30
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Where Can I Buy A 30 amp 250 v Slow Blow Fuse?
Originally Posted by richw46 View Post
Cool
I looked on their website and couldn't find them. Advance is my goto store, always friendly. I don't know why I'm having a hard time locally. If you can find them on the Advance site maybe you can post the link so the OP can order them.
I went into the store and bought it in person.
If I can reman we where I put the box I will get the part number from it.
It looked identical to the original except the 250 volts/32 volts part.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-23-2016, 08:56 PM   #31
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I had trouble finding slo-blow fuses locally, so I got a spare regular one just in case.
The original blew during my second year with the trailer. I also blew my spare the same day. I got another set of five regular ones. I have blown one more since.
I consider the regular ones good enough to keep using, though I would buy slow-blow if I could find some at a good price.
Note: I was in a NAPA store a couple months ago, and found some slow-blow 30A glass fuses. But they were shorter than the original in my Barker jack. So check carefully if you are buying the NAPA fuses.
The fuses I am using now are Bussmann BP/AGC-30.
SSquared is offline   Reply With Quote
Old 05-23-2016, 11:21 PM   #32
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
......Platt has them too, price is $2.29 for a pack of 5
Gee whiz. Thanks again rich. I've got to start thinking outside the box. I use Platt for residential ele supplies and think of them as res/commercial. I'll walk the 9 blocks tomorrow. My Napa order arrived today so I'll pick that up, but discuss the SB availability and also the new bade type and wiring jig with Platt.
CruizinDux is offline   Reply With Quote
Old 05-24-2016, 05:10 AM   #33
r carl's Avatar
Lin , Ne
You can change to a circuit breaker. NAPA should be able to get one of these.
http://www1.cooperbussmann.com/pdf/3...33b67204d0.pdf
Old 05-24-2016, 08:36 AM   #34
Thanks to all for your input. I found the 30 amp 32 v slow blows at Napa. It worked. I also called my power jack manufacturer Barker and they are sending me some of the correct fuses. They don't think the Napa fuses will last long before blowing. They actually recommended I use 40 amp fuses until I receive the correct ones from them.
jonnie3 is offline   Reply With Quote
Old 05-24-2016, 09:50 AM   #35
m.hony's Avatar
2013 30' Classic
My 12 volt 32 amp fuse has been working for a month or 2.
How long till the jack manufacturer thinks it will fail?
TAC #MS-10
Airforums #70955
Old 05-24-2016, 04:05 PM   #36
richw46's Avatar
Very interesting, I like it, thanks for the link.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 05-24-2016, 04:10 PM   #37
Long Island , New York
Any chance that swapping out the glass fuse-holder will void the warranty for the tongue jack motor in a newer trailer?
Hmmmm . . .
PS -- If it ain't broke don't fix it? The 30A 250v glass fuses may take a day or two to locate, but this technology is not going away in our lifetimes IMO.
Old 05-24-2016, 04:47 PM   #38
r carl's Avatar
Lin , Ne
Hmmmm . . .
Are you asking if swapping a 30amp glass fuse to a 30amp circuit breaker will void warranty? I wouldn't think so.
Old 05-24-2016, 04:57 PM   #39
murreywalker's Avatar
2011 23' FB Flying Cloud
Branson , Missouri
If you're looking for OEM fuses, just call Barker.
They sent me a three pack for nothing.
BTW, you're probably blowing the fuse with a bad switch in the head. I know.
They will sell you a head cover, and that will take care of the switch problem. I know about that too. ;-)
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 05-24-2016, 11:16 PM   #40
They didn't say how long. Just said to try it until I received the ones from them.
Old 05-25-2016, 05:02 AM   #41
2015 30' FB FC Bunk
Ayer , Massachusetts
Originally Posted by jonnie3 View Post
My Barker power jack blew a fuse. It's a 30 amp 250 v slow blow glass fuse and I've looked at Radio Shack, WM and other places with no luck. Anyone know where I can buy one of these elusive fuses?
From Barker. I had the same issue, they sent me some.
Ted S. is offline   Reply With Quote
Old 05-25-2016, 05:23 AM   #42
If there is a future electrical problem with the jack motor, or it burns out, you don't think the dealer is going to point the finger at the circuit breaker?
Replacing running light-did I blow a fuse? Knudsvig Lights - Interior & Exterior 4 01-31-2016 01:18 PM
Slo-Blow Fuse Holder Short? orange kayak General Repair Forum 2 06-03-2014 08:15 PM
Fuse Continues to Blow in Tow Vehicle tmeagle1 Lights - Interior & Exterior 6 07-01-2008 05:23 PM
