Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-22-2014, 08:19 PM   #1
ottawa (greely) , Ontario
Where are most common water leaks on airstreams
We're are the most common location for water leaks ,post your model of airstream and locations
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 04-22-2014, 09:01 PM   #2
Mixter's Avatar
1976 27' Overlander
1976 27' Overlander. During shell off resto, found lots:
  1. Tons of small leaks in the rivets along the ribs over the top of the coach, and down to the curve. Not many rivets leaked on the vertical sides.
  2. Vertical seams where the endcaps attached to the fuselage, and the vertical seams on the encaps- 1st 18" or so from the windows on the center panels- front & rear.
  3. Vista Views- the notorious leak between the glass and the gasket.
  4. Water fill. Cracked plastic causes dripping inside.
  5. Misc pop rivet here and there holding on a molding etc.
  6. I had very few leaks around window frames- mostly easy fix of cleaning and applying vulkem.
  7. No leaks from gaskets- even though all mine are junk.... they just have not generated any leaks inside.
  8. No leaks from horizontal seams.
Mixter is offline   Reply With Quote
Old 04-22-2014, 09:01 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
In general, every place that a sheet of aluminum is pierced (ie. rivet holes and seams), you have the potential for a leak. More specifically, door, window, and hatch seals will eventually leak and result in rot in those areas. The gasket/drip pan under your AC will as well. In a 70's era (and newer) trailer, the plumbing vent stacks rely on a rubber gasket that has a life of around five years. Also in those trailers, the geometry of the rear end steers water right into the subfloor I'm the rear.
Perhaps less common, but still leaky, are the roof vents, the roof mounted TV antenna, the refrigerator chimney, and the stove vent.
Old 04-23-2014, 07:41 AM   #4
dznf0g's Avatar
Oswego , Illinois
Only 6 locations...Front, back, top, bottom and both sides.
-Rich-
City Water Regulator - How Common a part? Gael79 Fresh Water Systems 15 09-01-2008 07:25 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
Most common problems with 1960s trailers? rluhr 1966-68 Caravel 10 08-21-2003 07:31 AM
