Old 08-16-2011, 07:59 AM   #1
moderator
Ottawa , Ontario
When did AS use OSB flooring (Oriented strand board)?
I seem to remember that it was used in the 1992 models, but can you help me to isolate exactly what years we know that OSB was used?
Thanks!
Looking to sell your Airstream or buy a different one?
Or maybe you need a part or just want to sell one?
Be sure to look in at http://www.airstreamclassifieds.com
Old 08-16-2011, 08:59 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
87 and 88
Old 08-16-2011, 09:28 AM   #3
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
1985
osb was in my 1985; full 3/4 inch hard to match with today's stuff; c channel still wanted 5/8; acquaintances have indicated no osb in their 93.
wmarsha is offline   Reply With Quote
Old 08-16-2011, 09:39 AM   #4
Shacksman's Avatar
1960 28' Ambassador
1962 16' Bambi
1967 22' Safari
Avonton , Ontario
2002 CCD Rots away real good!
Name:	100_5259 (640x480).jpg
Doug
VAC - TAC ON-1
62 Bambi
60 Ambassador Int.
67 Safari
72-20' Argosy
68 Tradewind
Shacksman is offline   Reply With Quote
Old 08-16-2011, 09:46 AM   #5
mutcth's Avatar
1977 Argosy Minuet 6.0 Metre
2007 23' Safari SE
Central , Connecticut
Doug, that picture makes me feel queasy. Makes me want to pay to restore vintage with Nyloboard - or just keep my aluminium-floored Minuet.
16' Bambis also had OSB up until around 2009. My understanding is that it's rather prevalent from the early 80s up until the mid-2000s.
Tom
mutcth is online now   Reply With Quote
Old 08-16-2011, 09:57 AM   #6
1973 31' Sovereign
1974 27' Overlander
1975 31' Sovereign
Americus , Also Valrico, Fl
Angry floor replacement material choices
Why can't pressure treated or marine plywood be used, especially around the perimeter..?. OR use pressure treated 1 x 6 or 8 and plane the boards to the desired thickness or route the edges only that go under the side wall. The later method will give you a 3/4" floor. Should last a long time and individual boards should be easier to install. Plus, I have experimented with insulating the boards bottom, as installing with styrofoam or spray foam to eliminate the fiberglass from becoming a sponge and holding water once wet. AND drain holes in the low spots of the belly pan let any water that intrudes find its own way out.
Jim & Mitzi is offline   Reply With Quote
Old 08-16-2011, 09:58 AM   #7
wasagachris's Avatar
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Send a message via Skype™ to wasagachris
Thanks!
Doesn't OSB stand for old soggy barf?
1973 Excella 500 31ft Center Bath
1963 Overlander 26 ft
1961 Sovereign 30 ft Custom
1955 Overlander 26 ft
1947 Liner 22 ft.
2010 Ford F450 Crew Cab Dually Diesel
TAC ON-11
Every day is a gift, but does it always have to be a pair of socks.
wasagachris is offline   Reply With Quote
Old 08-16-2011, 10:00 AM   #8
ventport's Avatar
Milltown , Wisconsin
You would have better luck asking for world peace, unicorns and rainbows.
ventport is offline   Reply With Quote
Old 08-16-2011, 11:02 AM   #9
moderator
Ottawa , Ontario
OK, so far I note that we have confirmed:
1985, 1987, 1988, 1992, (1993 not), and yet 2002 yes
mutcth has a couple of non-confirmed thoughts, a joke from Chris, and some wishes from Jim & Mitzi.
If you know what your trailer has, and if it is OSB, let us know?
Old 08-16-2011, 11:10 AM   #10
sandlapper's Avatar
1993 34' Excella
york , South Carolina
My 93 34 excella has OSB.
If I'm not here, I'll be somewhere else.
2007 Dodge Crew Cab 6.7 Cummins 6 speed manual DRW factory installed optional exhaust brake Leer Cap
12 Tires on the ground
Are you kind?
WBCCI # 3892
AIR # 43788
John & Susan
sandlapper is offline   Reply With Quote
Old 08-16-2011, 11:37 AM   #11
silverhilton's Avatar
1986 32' Excella
Surrey , British Columbia
My 1986, 32ft Excella has it, it works great as long as you can keep it dry....
silverhilton is offline   Reply With Quote
Old 08-16-2011, 11:56 AM   #12
tinbender's Avatar
2001 16' Bambi
1972 23' Safari
Piedmont Region , North Carolina
Osb aka landfill material
That is what it looks like when you find it rotted and falling through. My 2001 16' Bambi had it but it now has a 3/4" marine grade floor with 2 coats of gray epoxy top and bottom. Edges were routed to fit the channel, like mentioned above. Works good lasts long time......
tinbender is offline   Reply With Quote
Old 08-16-2011, 11:57 AM   #13
mutcth's Avatar
2007 23' Safari SE
C'mon - thoughts are good! Here's more confirmation that the 22' models had OSB up to at least 2005. I do know of a 1992 Excella with OSB floors - discussed it with their owner. Also I looked at a 2001 Bambi 16' (as mentioned above) that had it - the floor was sagging away, dipped in front of the entry door...
Tom
Old 08-16-2011, 12:41 PM   #14
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Not to add more confusion, but I think maybe it is not only a function of the year, but also the model.
Our 2005 Classic 30 definitely has plywood, but I'm not sure that all the different 2005 models did have.
This wooden floor issue - be it plywood or OSB is the thing I least like about our AS, I am really surprised that cannot - or choose not to - use something better.
Brian.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Laminate flooring: when to install? Phrunes Repairing/Replacing Floor &/or Frame 2 06-07-2011 05:52 AM
Floor prep on chip board flooring. airepal Floor Finishes 2 05-09-2011 02:48 PM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
Bamboo Flooring Argosy22 Interior Restoration Forum 1 01-23-2011 08:41 PM
