Old 11-13-2014, 12:52 PM   #85
2006 16' International CCD
Portland , Oregon
I recently posted about significant floor rot and mold from water damage in my '06 16' Bambi CCD (see thread below). The trailer is still at the shop, but the pics make me wonder if it's OSB. I'll update once I find out.
http://www.airforums.com/forums/f44/...ea-127757.html
Pea Pod is offline   Reply With Quote
Old 11-19-2014, 12:12 AM   #86
Lincolnton , North Carolina
As a wannabe, I find this discussion very enlightening. We're trying to decide whether to buy an older used unit with the idea of doing a shell-off or to buy newer. Sounds to me like buying older and putting in the floor that you KNOW is sound is the way to go. Are there any serious weight penalties for replacing the OSB or plywood with a composite material like Trex or Nylodeck?
northmeck025 is offline   Reply With Quote
Old 11-19-2014, 12:41 PM   #87
Ottawa , ON
Originally Posted by BearScream View Post
So if I understand Airstreams response Aage, they have not used OSB since 2007 except for two (unspecified) models. So it is still possible to find it in a 2007. No safe harbor that.
So far (and I have yet to tabulate all the data) the only safe means to see if you are potentially buying a TT with an OSB subfloor seems to be to poke around in it to check for yourself.
Luckily, I don't think it would take much looking to confirm one way or another.
Old 02-07-2015, 11:16 AM   #88
mrdually350's Avatar
1995 34' Excella
Bellbrook , Ohio
My 1995 34' Excella has plywood. My 2009 SOB that it replaced did not. It is waiting on some OSB repairs before I sell it. The Excella is in better shape, (except for the sagging padded ceiling) even though it is 14 years older.
1995 34' Excella, front kitchen, queen bed, 150 watt solar, Trace inverter, Hensley Arrow hitch
2003 E450, 7.3 PSD, retired ambulance fitted with a stretched extended body from a '98 E350
mrdually350 is offline   Reply With Quote
Old 02-07-2015, 12:20 PM   #89
1998 19' Bambi
Parkville , Missouri
My 98 Bambi has plywood..easy way to check open a store age door an look
MoBambi is offline   Reply With Quote
Laminate flooring: when to install? Phrunes Repairing/Replacing Floor &/or Frame 2 06-07-2011 05:52 AM
Floor prep on chip board flooring. airepal Floor Finishes 2 05-09-2011 02:48 PM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
Bamboo Flooring Argosy22 Interior Restoration Forum 1 01-23-2011 08:41 PM
