Old 09-11-2011, 06:08 PM   #57
"CLOUDSPLITTER" (tahawus)
ROBERT CROSS's Avatar
Hoover Beach , "Niagara Frontier" NY
Images: 53
Marine grade, the same?...yes but not quite.
A boat is built to get WET and last, an AS is built to last, the floor gets wet and doesn't.
If you can't make them so they don't leak.....at least make 'em so they don't rot away right away.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
ROBERT CROSS is online now   Reply With Quote
Old 09-12-2011, 10:28 AM   #58
2006 22' International CCD
2007 Base Camp
Quesnel , British Columbia
That really is a good point... no wood, unsealed floor is designed for continuous water exposure. But, if Airstreams are more prone to leaks than others, going to a composite floor would solve lots of problems... go with 1/4 less wood, and laminate the whole thing in fibreglass. Or, go super-cool and do some carbon over foam-core.
Friday is online now   Reply With Quote
Old 09-12-2011, 10:30 AM   #59
2007 Base Camp
Oh, and I can confirm the floor of my 06 22' is OSB.
Old 09-12-2011, 01:05 PM   #60
BEWARE of the CAT
w7ts's Avatar
2010 31' Classic
Longmont , Colorado
Originally Posted by david686 View Post
I replied to AS's email for some OSB information and just got this reply.
"We have not used any osb flooring since 2007 model year and that was only on 2 models.
Thank you,
Airstream Customer Support Team
Sent: Tuesday, August 30, 2011 5:18 PM
To: customersupport@airstream.com
Subject: Re: Fwd: Floors (contact us from airstream.com)
I might not have made my email as clear as I could have. What I should have asked is; "Why doesn't AS use only pressure treated plywood for the floors and not OSB in some cases? It appears that some trailers have OSB as flooring."
Does the above AS statement appear to be true?
Has anyone found OSB in 2008 and up?
Ken
My 2010 Classic has plywood.
w7ts is offline   Reply With Quote
Old 09-22-2011, 10:54 AM   #61
1981 31' Excella II
Orlando , Florida
There are also design flaws that have not changed in 30-40 yrs that would help reduce leaks and therefore rot. The bumper plate area seems to leak on all models. The gaps in the C-Channel that let any water come into direct contact with the flooring. The curved sections have flooring relatively exposed compared to the straight sides. The sides are protected by the C-channel at the base of the floor and another channel that covers the ends of the plywood. If this bottom channel was continued all the way around, many leaks or at least the negative effects of the leaks would be eliminated. Then you have to ask where is the profit in making a product that last decades. Maybe the 5-10 yrs lifetime for SOB trailers is more profitable and it also fits the American Dream of everything is disposable and renewable. How can we have growth if stuff lasts forever. What is the profit in that.
Perry
Old 09-22-2011, 09:02 PM   #62
moderator
Ottawa , Ontario
I'd like to mention that I did not mean this thread as a way to criticize Airstream, rather, I simply wanted to find out which years that OSB was used.
I've got to admit that the information that you all have kindly given me is, to me at least, surprising. But again, I only wanted to know how widespread the use of that material is, and no more.
Therefore, I ask that we do not stray from the title question. There are plenty of other threads that can be used if you want to discuss problems with your TT.
Thanks very much for your co-operation.
Looking to sell your Airstream or buy a different one?
Or maybe you need a part or just want to sell one?
Be sure to look in at http://www.airstreamclassifieds.com
Old 09-22-2011, 09:18 PM   #63
Ridgerunner3's Avatar
2002 25' Safari
Tennessee Ridge , Tennessee
We just bought a 2002 Safari 25. It has plywood flooring.
Ridgerunner3 is online now   Reply With Quote
Old 12-22-2011, 05:51 PM   #64
"Tinbad ... the Trailer"
Del Gurney's Avatar
Seattle , Washington
My '05 25' (delivered '06) fortunately has ply.
My 2cents: Having worked on boats my whole life; Marine Grade ply
a) uses high quality tight grained wood with out knots
b) uses a finish veneer for attractive varnished appearance
c) uses water resistant adhesive.
d) employes 5-7 individual layers of wood veneer (as opposed to 3-5 for reg. ply) This is for a higher glue to wood ratio for strength.
e) will rot faster in a marine situation as salt deposits never dry out lest washed.
f) it weighs more ......maybe it was a weight issue with AS? Or too rigid for a flexing trailer. Density/strength vs. weight as usual.
STILL, be nice if they had sealed it with maybe marine grade West System epoxy.
Del Gurney is offline   Reply With Quote
Old 02-04-2012, 09:19 PM   #65
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
weight ? thats funny osb is 12.00 a sheet at our lowes (5/8,3/4 is 14.50 ) i use furniture grade and waterproofing about 40.00 a sheet.
i see so many osb disasters that it hurts to think about it. most sobs are using osb,recently had a class c in , an 08 the slideout seals were installed wrong though it made it through the warranty period th floor rotted out for 6' and slideout had to be removed to repair , cost of osb in this situation went to 11,000.00 . did a floor repair last fall on an 05 22' ccd also frame repair , water got in at rear wall as usual. had to strip interior to door from rear wall to replace rotted osb. repair sagged outriggers and rear of frame. jackson centers est. 9800.00 i felt sorry for cust with 1rst a/s (bought used)did job for less than 5000.00 but don't really want to do another.
i'll stick with the antiques
crestonrv is offline   Reply With Quote
Laminate flooring: when to install? Phrunes Repairing/Replacing Floor &/or Frame 2 06-07-2011 05:52 AM
Floor prep on chip board flooring. airepal Floor Finishes 2 05-09-2011 02:48 PM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
Bamboo Flooring Argosy22 Interior Restoration Forum 1 01-23-2011 08:41 PM
