Old 09-07-2013, 09:27 AM   #29
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Originally Posted by dkottum View Post
This is the Sonin moisture detection meter I and others here use. It is battery operated and has a probe at the end of a cord to get into tight spots. Works very well. I sharpened the probes a little extra.
Sonin 50211 Rapitest 10% to 28% Pinless Analog Wood, Concrete, Plaster, Carpet, and More Moisture Meter - Amazon.com
doug k
Where do you recommend testing? Do you push the pins through the vinyl floor?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 09-07-2013, 10:25 AM   #30
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Thanks. Was about to ask same.
I have likewise endured that Airstream disappointment. The FaN was purchased from a nice indoor showroom (during one of the rainest winters here on the wet coast).
So, the besotted one brings 'er home and leaves 'er outside - and notices a few drips from a bathroom wall seam.
The dealer repaired it - and a couple of small ones since that were easy to track down; one involved the fantastic fan seal, and the other one was from the smaller bedroom window.
The experience has put me on constant "leak" alert. So, a couple of nights ago we had heavy thunder and rain - I go into the FaN and there's a wet spot just inside the door. Oh no! Upon closer inspection, the "wet spot" is shaped like a dog's paw. Whew! Ole' Rover jumped in and out when I left the door open for a sec.
The Airstream "honeymoon" period tends to be more realistic than romantic. You don't want to trade 'er in because you still love her/him/it, but you realize the relationship is going to involve some degree of work. (BTW, no more leaks for over a year and a half now).
Fly at Night is offline   Reply With Quote
Old 09-07-2013, 10:54 AM   #31
Ottawa , ON
Have you travelled in her yet, FaN? For me, that is a real test of leaks.
♫ Rollin', rollin', rollin, keep them doagies rollin', rollin', rollin', rollin', rawhide ♫
- Theme from "Rawhide"
Old 09-07-2013, 02:09 PM   #32
Hi Aage, the FaN still has less than 2,500 km on her, but we hit heavy, driving rain in the Cascades on the last, and she was as tight as a drum.
Am back in the driveway for a few days; getting reading for my biggest trip. Am heading east on Monday. Not as far as your part of the woods, but I will be on the road for 2 - 3 weeks. I guess my next big leak test will come this winter. If I pop another one - it won't be like the first feak-out. She shall be fixed.....and ready to roll, roll, roll, roll on....(caution Canadian content)....down the highway again!....
Old 09-08-2013, 05:32 AM   #33
LFC
Memphis , Tennessee
Originally Posted by PharmGeek View Post
My new unit will be here in october...
Are your feet feeling wet and cold yet ?
LFC is offline   Reply With Quote
Old 09-08-2013, 06:10 AM   #34
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Yes, I go around the perimeter of the interior, paying special attention to leak prone areas such as under the pano windows and entrance door. Some cabinets and appliances prevent getting behind them. Also probe around the shower.
My probes are almost needle sharp so they make tiny openings in the vinyl which "self-heal" somewhat soon afterward. They are virtually invisible.
Have found two leaks, one under the entrance door hinge that worked loose, tightened and resealed the hinge. Another (very minor) at the floor inside the left A-frame (I resealed top of the exterior front rub rail). I suspect that was caused by too stiff a hitch (Andersen) I was using, also had the corner banana wrap tear loose from a rivet there. So bought a hitch with more flexible w.d. bars.
doug
Old 09-08-2013, 07:11 AM   #35
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
No col feet - hopefully they stay dry with the advice here
PharmGeek is offline   Reply With Quote
