Old 04-07-2012, 11:36 AM   #15
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by barts View Post
I've had poor luck with pop riveters & stainless rivets; they don't seem to live very long. I prefer stainless rivets for high load tasks like re-riveting the hinge on top of Airstream windows....
I haven't done that many stainless, but would expect shorter tool life. They really are tough!
One handy tool I made is a nose extension for the rivet tool - this helps set rivets down in recessed areas such as the window supports.
- Bart
That is a great idea. I have been meaning to make one myself. In the past, I've used stacks of drilled-out pop rivet heads for a spacer by sliding a few over the mandrel before inserting it in the tool, but you don't always have those around.
Vaughan
Old 04-07-2012, 12:06 PM   #16
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
For a hand operated tool I prefer the Marson HP-2. I sold them for many years off of my Snap-On truck. Not one problem. None ever broke. The only thing that went wrong was the jaws would wear out from use. A new set of jaws was about 40 cents, so I kept them in stock and replaced them no charge.
The tool with a small assortment of rivets in a nice case is available at Amazon for about $30.00.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-08-2012, 09:37 PM   #17
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
Stainless rivets,
Originally Posted by Aerowood View Post
What kind of rivets, solid shank (buck) or blind?
Aerowood, where would I use stainless rivets on an airstream? Just wondering
How about a pnuematic pop rivet gun to replace the interior? Think it's a good idea? I have a 20' GT (1965)
I was thinking the two kits from VTS to start, gives me a little of everything including an olympic shaver.
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 04-08-2012, 10:43 PM   #18
Maniacal Engineer
barts's Avatar
Menlo Park , California
TIMK
I use stainless pop rivets when I want extra strength and I can't use a bucked rivet such as fastening window hinges using reversed pop rivets
or securing the bottom trim rail in the rear of the trailer.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-09-2012, 04:00 AM   #19
1969 18' Caravel
Jensen Beach , Florida
I bought the least expensive air over hydraulic pop rivet gun from HF (about $45) and it works OK but it does jam quite a bit. Special care has to be taken to be sure the spent rivet stem is clear of the jaws before driving another, but usually a simple shake of the gun will do this. It is much more troublesome when using olympic blind rivets and any kind of sealer as the sealer causes the spent stem to hang up in the gun and causes problems with the next rivet driven. It's easy to unjam, just screw off the nose piece that holds the jaws and clear out the stem pieces, but it takes time . Also the nose piece won't fit in tight places and I had to resort to a hand driver on many interior wall moldings. In hindsight, I don't think it was worth it for me as it didn't really save that much time.
I also couldn't justify the money for a head shaver, a small sanding disk in a drill was good enough for the 200 olympic heads I had to do. It only takes a few seconds for each one and I seriously doubt anyone would have an issue with the results.
As for a buck riveting gun, I borrowed one from a buddy who worked in the aircraft industry. He said " I haven't used it since I stole it 7 years ago". An add on craigslist would probably turn up a used one for a reasonable price.
DontBSilly is offline   Reply With Quote
Old 04-09-2012, 07:18 AM   #20
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Jonesway at Fastenal
Originally Posted by RickDavis View Post
Has anyone tried the air powered ones like Harbor Freight sells??
I recently purchased a Jonesway air/hydraulic riveter at Fastenal. It was sitting there on the shelf for years so the manager gave me a great deal. It takes it a lot of grunt to pull 3/16" stainless rivets, but it got it done. I wish I would have bought one years ago.
For the regular manual blind riveter, I got a new Pop brand riveter from Brown Aviation and Aircraft Tools a while back. The Arrow swivel head had to be relegated to the scrap metal pile. I very much prefer the non swivel version.
For solid riveting, I have the solid rivet kit from VTS. Works great.
Lance
Top is offline   Reply With Quote
What did a Classic Motorhome Cost New? Keyair Classic Motorhomes 42 08-12-2012 06:39 PM
What's this? Drive-by photos nesvt Vintage Kin 19 04-25-2012 05:49 AM
What's playing on your 8-track... Mexray Audio, Video & TV 17 04-23-2012 07:06 PM
Stolen in Seattle Area - Brand New 31 foot Airstream! Airstreamnw Our Community 47 03-28-2012 05:35 PM
What Kind of Rivet Do I need? Why Olympic rivets? Kyle-King Ribs, Skins & Rivets 10 03-27-2012 09:47 PM
