Old 04-10-2015, 06:03 PM   #1
lewster's Avatar
Naples, FL , Hood River, OR
What's Wrong Here??
HI Gang,
I'm in the middle of a solar/battery/fridge upgrade on a 19 and I found a few 'anomalies' that the PO left for the present owner. I'll post some shots of the most egregious below.
Your comments about what's wrong here should be fun and informative for readers of this thread. I'll add some details during the course of the thread.
Let's see who gets them right.......
Go for it!
ID:	236009   Click image for larger version
Old 04-10-2015, 06:08 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
OK, I'll start with one: mismatched batteries.
2012 Dodge Durango Hemi/AWD
Old 04-10-2015, 06:23 PM   #3
Freq Flyer's Avatar
2012 20' Flying Cloud
Vero Beach , Florida
Two things with the first pic... AGM and flooded cell batteries together, and obviously different ages (don't put old and new batteries together). I don't recognize either of the following pics.
Freq Flyer is offline   Reply With Quote
Old 04-10-2015, 06:31 PM   #4
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Is the third one a tv antenna mount? Or what's left of one?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-10-2015, 07:05 PM   #5
lewster's Avatar
Very close on the battery issue. One AGM DEEP CYCLE battery and one.......wait for it........flooded STARTING BATTERY!!!! WHAT WERE THEY THINKING????
These will be replaced by 2 new, perfectly matched Lifeline GPL-4CT AGM 220 amp/hour golf cart batteries. I'll be documenting the riser upgrade required for these taller batteries and due to popular demand....... will post as required.
Still need more comments on the other 2 shots. You won't believe the truth when it comes out............
Old 04-10-2015, 07:09 PM   #6
lewster's Avatar
Yep, it's a mount for a crank-up TV antenna......shown removed from the base. The real estate is needed to place a solar panel directly over it, and the hole gets a hard foam plug and liberal grey SikaFlex to seal it. It will be replaced by a Jack digital amplified directional antenna in another location.
But it's the stuff around the base that's offensive.
*hint: there are 2 offending problems here...........and they are also directly related to the other shot..............Look carefully at the middle shot.
*hint 2: in the center photo, that's the retracted awning in the foreground
Old 04-10-2015, 07:41 PM   #7
1989 34.5' Airstream 345
Ebro , Fla Panhandle
If that is not rippled metal in the second pic, could they have put a rubberized fabric skin over the roof ?
Cheers Richard
tevake is offline   Reply With Quote
Old 04-10-2015, 07:54 PM   #8
strshpntrprz's Avatar
1973 23' Safari
Reese , Michigan
Wow
As a semi-retired diesel truck mechanic I may see lots more than most people would. The most obvious is mixing types of batteries-- the blue top being a best-- AGM and the other having cell caps to check- refill the water level, they would work-- but not an ideal mix, they are so different in charging requirements. They look to be of a mix of an old battery and a new one, not the best either as they should be replaced as a pair, and also check that your new batteries have about the same date of manufacture, that will be stamped into the top of the side of the battery, a battery can sit at a dealer for up to a year before being taken back to the battery dealer to be stripped of it's name and recharged and sold as a blemish at about half price. The battery hold down in the center looks WAY too close to the positive post of both batteries to be safe from a direct short to ground, and the biggest problems you can have. I also do not know how much room between all negative and positive cables there is, you do not want them touching and rubbing through and shorting out, a few layers of electrical tape will go a long way to help that, and it is cheap and easy to do. All issues are easy to fix, and you want to, before you see smoke behind you as you are going down the road to the start of your two week road trip, an ounce of --- you get the picture. I'll leave the other pics for others-- my 1973 does not have that on it's roof. safe travels Gene
Gene and Sharol in starship enterprize (earthbound) don't grow up, it is a TRAP ---repairing, not restoring since 1999
strshpntrprz is offline   Reply With Quote
Old 04-10-2015, 07:56 PM   #9
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
My guess is duct tape.
Landrum is offline   Reply With Quote
Old 04-10-2015, 08:02 PM   #10
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
He also has both positive and negative cables attached to the same battery. In a proper parallel wiring the positive cable should be on one battery and the negative cable attached to the other.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 04-10-2015, 09:01 PM   #11
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
foreground
Silicone sealant has to be one issue. Can't see problem 2 yet.
www.nesa.org
Air No. 6427
Old 04-10-2015, 09:19 PM   #12
Got gandkids?
Problem No. 2.
Almost looks like somebody tried to fabricate a cover to fit around that antenna base plate. Maybe because it was leaking? Then did not actually fasten it to the roof of the trailer with any mechanical fasteners.....Silicone used to seal the "repair" and hold it in place?? Maybe a similar "repair" in pic no. 2? But I can't tell what they were trying to cover over with the patch job. Maybe a leaking window that was broken out?
How close am I?
www.nesa.org
Air No. 6427
Old 04-11-2015, 03:53 AM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The antenna base sealing job looks like it was done with rubber roof patching tape.
The photo with the awning is too close up to get perspective.
Old 04-11-2015, 06:14 AM   #14
lewster's Avatar
Getting closer!!!!
I'll let the thread run a bit longer and give the actual answers later today.
Buck rivets look wrong?using wrong air hammer bit? shadeemry Ribs, Skins & Rivets 11 06-07-2014 07:42 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 07:04 AM
Look under here and tell me what's wrong connorsa Ribs, Skins & Rivets 6 07-13-2009 09:51 AM
It is here! Well, almost here... 1973 Ambassador Pschoerrn 1970 -1973 Ambassador 10 05-20-2005 02:56 PM
It's here! It's here! Hit'the'road 2002 - 2005 International 54 11-30-2004 10:00 AM
