Old 04-11-2015, 07:46 AM   #15
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
If not rubber roof patching tape, is it a rubber roof membrane used as a patch, and the same around the old antenna mount?
Chris
Old 04-11-2015, 08:34 AM   #16
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
looks eternabondish to me. not a good job of it maybe.
dsrtgrls is offline   Reply With Quote
Old 04-11-2015, 08:49 AM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
What's Wrong Here??
The thing I see that will burn an Airstream down is the routing of the cables.
The positive cables seem to be lying across the negative cables and lying across the grounded battery hold down. In either case abrasion can cause a big short that can burn an Airstream down really fast.
The rest of the stuff is stupid, the cables are dangerous.
I always take extra care with the routing and securement of unfused battery cables, limiting what the cables can possibly touch, and double insulating at securement points.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-11-2015, 09:30 AM   #18
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Back yard mechanics just make your job so easy Lew!
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 04-11-2015, 05:44 PM   #19
lewster's Avatar
Naples, FL , Hood River, OR
I started this thread as an example of what NOT to do to your Airstream. In this case, the PO was responsible for all of the travesty I have been correcting during the course of the present owner's solar/battery installation and upgrade.
Here a couple more shots of what I encountered today:
ID:	236085   Click image for larger version
Old 04-11-2015, 06:08 PM   #20
lewster's Avatar
The top pic is.....you guessed it dsrtgrls........ETERNABOND TAPE (EB tape)!!!!! This crap was placed down the seams at the edge of the roof all the way....front-to-back, along with 'sealing' around the fans/vents, front and rear cap seams and antenna base.You ever try to remove one of these Winegard crank up bases that Airstream used to use? Aside from the 12 screws that hold it to the roof, the factory beds it in liberal amounts of SikaFlex. THEY JUST DON'T MOVE!!!
THIS STUFF (EB tape) DOES NOT STAY DOWN AND SHOULD NEVER BE USED ON AN AIRSTREAM!!!!! It's like silicone (which I'll get to in a minute). Once it's down, it's very hard to get off clean and it leaves a residue that is a sticky mess.
And speaking of silicone, not only did they use this garbage tape liberally, they ran........you guessed it........silicone along both edges of the Eternabond tape. Guess they didn't have confidence in it either. The top pic shows how it was detaching from the front edge of the rear cap seam.
The second pic is of the front dead vent that is being replaced with a MaxxFan. It had the entire edge covered with 3" EB tape, but due to the chemistry of the plastic in the vent bezel, I was able to get it up with almost no residue. The silicone around the edges is another matter!!!!!
And for the batteries......lots of good answers!! J.Morgan was spot on about crossing positive and negative cables, strshpntrprz had a good observation about the proximity of the hold-down (which is frozen at the moment) to the positive terminal, Jim and Susan caught the silicone, J & S and overlander63 got pretty close on the antenna base and Dave added some encouragement!
The shot with the awning cover was another of the EB tape peeling back from the surface.
The last shot of the vent also showed that the PO deliberately removed the factory SikaFlex layer that they use to seal such items so the EB tape would lay flatter? REALLY???????
And the piece-de-resistance........ the roof cap for the black tank vent pipe, which is fairly new.....was totally sealed with silicone!!!!!!!
Some folks just don't get it.....but you guys are getting MUCH BETTER!!!!
Thanks to everyone for your comments!!!!
Buck rivets look wrong?using wrong air hammer bit? shadeemry Ribs, Skins & Rivets 11 06-07-2014 07:42 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 07:04 AM
Look under here and tell me what's wrong connorsa Ribs, Skins & Rivets 6 07-13-2009 09:51 AM
It is here! Well, almost here... 1973 Ambassador Pschoerrn 1970 -1973 Ambassador 10 05-20-2005 02:56 PM
It's here! It's here! Hit'the'road 2002 - 2005 International 54 11-30-2004 10:00 AM
