Old 08-18-2014, 02:47 PM   #1
1961 24' Tradewind
Reading , Berkshire
What's this on my 1961 Tradewind
There's a home made blanking plate covering a hole near the door, my question is: what was this hole originally used for?
Tucked away inside is what looks like some factory 12v wiring. Behind the hole, between the outer and inner body skins is a round backing piece which can only have been put there before the inner skin was installed.
ATurner is offline   Reply With Quote
Old 08-25-2014, 02:07 AM   #2
cdmagda's Avatar
Images: 51
I would guess maybe an entry light...
cdmagda is offline   Reply With Quote
Old 08-25-2014, 02:04 PM   #3
Jimbcole's Avatar
1958 17' Pacer
Tryon , North Carolina
That appears to be the size for the whip antenna.
Jimbcole is offline   Reply With Quote
Old 08-25-2014, 06:47 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My 66 Trade Wind has a radio antenna mounting hole that looks like your photograph. Zoom in on my front view curb side and you can see the antenna base. It's round with three fasteners.
David
Name:	1310 Exterior Front Street Side.jpg
Old 08-27-2014, 12:11 PM   #5
1961 24' Tradewind
Reading , Berkshire
Thanks for the replies. My initial thoughts were that it was for an antenna but I think I've ruled that out because: a) there's an old antenna mount already fitted (obscured by the door in the photo) and b) there's a 12v power cable present.
Old 08-27-2014, 12:15 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It is for a removable porch light. You see em for sale on Ebay sometimes.
1961 Bambi :: 1961 novus1 Airstream Registry Discussions 0 05-22-2012 06:53 PM
1961 BAMBI :: 1961 Airstream BAMBI SILVERSAILOR Airstream Registry Discussions 0 08-19-2011 08:31 AM
1961 Tradewind Tad Pole 1959-69 Tradewind 5 09-18-2008 09:56 PM
Region 9 Auctioning 1961 TradeWind Pahaska WBCCI Forum 7 10-31-2005 11:22 AM
