Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 12-08-2012, 08:11 PM   #101
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
As far as jacks go, I don't use them on my 30' Classic W/SO, I used to use a wooden "helper", but I found this one and it is the only way to go IMHO. Again, a little spendy until you need it.
http://www.genuinehotrod.com/itemgroup/trailer-aid
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 12-08-2012, 09:13 PM   #102
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Trailer Aid
Trailer Aid is a great device for those with tandem axles. List price $52 but it can be ordered off Amazon for $34.48.
When I swapped out my 15" wheels for 16" wheels, I took my Trailer Aid to the tire place. They used it to change out the new tires and rims in the parking lot. Much better than letting them try to jack up the trailer and potential miss the jack location.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2022 Ford F350 King Ranch, 6.7 Diesel, 4X4 (Big Red)
WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 12-08-2012, 09:15 PM   #103
dznf0g's Avatar
Oswego , Illinois
I, knock on wood, haven't had a flat....ever on a tandem axle trailer. But, why wouldn't I just use my lego blocks I already have on board? What am I missing?
-Rich-
Old 12-08-2012, 09:32 PM   #104
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have never had a flat on my trailer either, but had two tires at two different times, on our Alaska trip go bad. I used my Trailer Aide Plus both times. I think that the cupped area on the Trailer Aide Plus would hold it more steady and they sure are stronger than leveling blocks. I also have leveling blocks, for leveling. Many people have used them for changing tires without any problems, so it's just whatever you choose to use.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 12-09-2012, 05:37 AM   #105
Florida 55's Avatar
Images: 42
Lego blocks should work fine for changing tires. Trailer Aid may be a little safer due to the indentation which holds the tire bearing the weight of the trailer. It may also be easier to use than Legos if you are off the hard road surface on uneven soil or gravel.
I've used Trailer Aid once to change a flat tire. It helped make the operation fast and safe. Depending where you are when a tire goes flat fast can be a very good thing. When I'm driving on the highway, for safety and speed in the event of a tire incident, Trailer Aid rides just inside the tailgate with an orange cone, a box with three foldable emergency triangles, and my large 1/2 inch socket wrench with the appropriate size socket. I can change a truck or trailer tire very quickly. The most time consuming part of the operation is getting the spare out from under the trailer or truck.
Chuck
Old 12-09-2012, 11:09 AM   #106
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Legos have to be piled up pretty high to get the other wheel off the ground. You might need 2 sets, but I guess you can lift it high enough with 10. Some sets are 8 (ones sold at CW) and some have 10.
It doesn't seem as safe at that height as 2x. And Legos eventually start breaking, so I'd watch for that too.
Gene
Old 12-09-2012, 12:24 PM   #107
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
The tool box is certainly an interesting question! I approached it like this - -
What would I know how to fix?
What would be feasible to fix on the road?
What would I need to McGyver something for a short run?
What do I need for basic maintenance?
I have no knowledge for how to fix a car engine for example. Or replace brakes, or install a water pump and all those kinds of things. I do want to be able to change a tire, torque my lug nuts, tighten my hitch parts, replace blown fuses, and maybe McGuyver something for a few miles.
So I pared my tool kit down. I have a torque wrench with the sockets I need for wheels and hitch, tire tools, screwdriver set, a hammer, vice grips, tire gauges, lot's of kinds of tape, epoxy, 12g electrical wire, nuts and fuses, small wire cutter and stripper, jumper cables, coat hanger wire, some sharp utility knives. Not much beyond that. With the exception of the torque wrench, it fits in a medium sized heavy plastic toolbox.
So, I am definitely NOT in the "all contingencies" mode. I do know a fella who is in that mode. The back end of his PU is a full blown workshop full of tools of every description. He is a good guy to have a on a rally!
mstephens is offline   Reply With Quote
Old 12-09-2012, 01:49 PM   #108
dznf0g's Avatar
Oswego , Illinois
Gene
But the AS axle only drops...what maybe 4"? That's only 3 legos high. I do carry 2 sets anyway (and have found some brands break and some don't) as I use them under the stabilizers as well as under the wheels. Sometimes in a real uneven site I even have to use 2 or 3 under the tongue.
I get what you are saying for a leaf spring/equailzer type suspension.
-Rich-
Old 12-11-2012, 03:41 PM   #109
Master of Universe
Gene's Avatar
I found is it more than 3" and less than 4" to get the wheel off the ground. I thought the Legos are 1" high—they look that way, but I never measured them.
I have no doubt they can work, but I feel 2x pieces are more stable. I think the webbing can suddenly split, especially if used under the tongue jack or stabilizers. I think those metal parts are more likely to start to break the webbing and if that happens with a tire on 3 or 4 levels of Legos, I'd prefer a second means of support under the trailer.
The Legos are a lot lighter than carrying around a bunch of 2x lumber and if you have a weight problem in the tow vehicle, I can see wanting to use Legos.
Gene
Old 12-11-2012, 03:59 PM   #110
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Have not tried to change a tire with the plastic blocks. But using them for leveling makes me think it might be hard to get it high enough. If you are on pavement the stack slids if it is more than 2 high unless it has a long taper. If on ground the weight pushes the stack into the ground.
Old 12-12-2012, 07:20 AM   #111
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I had package of these plastic leggo-type stacking blocks. As you say, they move around when trying to back up on them and, in my case, they even managed to get mangled. I turfed them and carry several 2x6 boards that are 2-feet long with a tapered edge in the back of the truck.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 12-12-2012, 07:38 AM   #112
dznf0g's Avatar
Oswego , Illinois
Hmmm, I've never had them move around on me on any surface. I did have one brand (can't remember the name, but certainly remember the construction look and feel) that cracked to pieces when used on uneven ground and gravel. The new ones feel like a much more dense material and are physically thicker. They also cost $28 as opposed to $16 at CW.
This is one of those casee where "youz getz what youz payz for".
Yes Gene, when stacked they are 1", except for the top one whose "male tabs" are exposed and add about another 1/2 - 3/4". So three high gets you to about 3.5 - 3.75" of height.
Probably should try this at home before I find myself on the side of the road......
-Rich-
Old 12-12-2012, 12:35 PM   #113
Master of Universe
Gene's Avatar
Dzn', didn't think about the "make tabs". I have had them slide. I've bought them through Amazon which sells the sets of 10.
Gene
Old 12-12-2012, 06:18 PM   #114
Vintage Kin
Fort Worth , Texas
I haven't been pleased with the inexpensive ones I've had either. Recently cut up some 2'X10" pressure treat in 6' lengths (at 12' used them to slide the new A/C unit to the roof from truck tailgate early this year . . and slide the old one down, much as I wanted to just chunk it over the side, ha!). I have one board under the curb tandem and three under the street pair to level at this park (and keep tires off of gravel better described as rocks). Since the back of the truck is a "garage" this was an easy decision. Haven't decided yet about stabilizer pads . . the lego's are okay for that for now.
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
Cardboard Box Oven v2.0 + 20" Pizza GCinSC2 Stella's Kitchen 1 09-18-2011 03:28 PM
Termites in my Trailer acbolton Winterizing, Storage, Carports & Covers 4 06-09-2011 08:36 AM
How do you deal with your trailer while exploring? mikescha On The Road... 18 02-21-2011 11:36 AM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
