Old 02-24-2007, 07:26 AM   #1
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
What's in your Airstream toolbox?
What tools and related supplies do you pack when you go camping for Airstream or tow vehicle emergencies or repair work?
Some things we never leave home without are:
  • duct tape
  • wire ties
  • socket set
  • hammer
  • pliers
  • wheel jack
  • lug nut remover
  • flashlight
  • small pry bar
  • screwdrivers
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 02-24-2007, 07:32 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Also:
  • vise grips
  • multi meter
  • channel locks
  • swiss army knife
  • rope
Richard
Old 02-24-2007, 08:03 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
WD40
rivets and rivet gun
Old 02-24-2007, 08:35 AM   #4
Images: 59
Also:
  • sidecutters
  • electrical tape
  • two small hose clamps
  • small roll putty
  • 5 min epoxy
  • crescent wrench
  • flare nut wrenches
  • rags
  • hand cleaner
Old 02-24-2007, 09:13 AM   #5
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
I found that for fast secure belly pan fixes on the road, stainless steel pan head screws do the job, so I take several sizes with me, in addition to much of the above, and my cordless drill.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 02-24-2007, 10:10 AM   #6
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
In addition to most of what has already been mentioned (what’s a channel lock remover?) my “travel kit” also includes a number of other spare parts and maintenance items.
- spare set of bulbs
- spare set of fuses
- graphite spray
- silicone spray
- electronic contact cleaner spray
- spare hose/faucet washers
- 12 volt air compressor
- tow rope
- wheel bearing grease
- Teflon grease
- spray bomb flat tire inflater
- tube of di-electric grease
- tube of battery terminal grease
- tire pressure gauge
- spare hot water tank plug
- battery terminal cleaner
- spare hitch pin/lock key
- spare Hensley kit (just got the Hensley)
- 1 bottle jack
- 1 axle stand
- 1 high density foam type mattress pad
- 12 volt trouble light
- 4-way wheel wrench
- torque wrench
- CD – the best of Willie Nelson
When I look at the list it seems kinda long – but it packs to be pretty compact – and – with the exception of the bottle jack – there is not a lot of weight. There is nothing on the list that hasn’t seen good use – if not by me – then by a neighbour.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 02-24-2007, 10:12 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Torque wrench is a must have as are fuses along with most of what's been said here.
Old 02-24-2007, 10:43 AM   #8
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
-Zip Ties
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 02-24-2007, 10:47 AM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Jay
Which includes "On the Road Again"?
Richard
Old 02-24-2007, 11:46 AM   #10
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The first item into my AS tool kit was a kit box of three semi-rig emergency reflector triangles, the kind w/ cast iron inserts to keep trucks from blowing them down... ($8 at Northern Tools outlet store in Hudson Wiscosin) I know they are kind of heavy to carry around, I'm thinking if I don't get run over trying to place them correctly they might save someone else grief when Murphy's Law is richly rewarding me when old Murphy has got me playing on the road again...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 02-24-2007, 12:23 PM   #11
RangerJay's Avatar
2002 19' Bambi
Images: 44
... kind of our motoring anthem ...
Jay
(Oscar Wilde)
Old 02-24-2007, 08:17 PM   #12
yukionna's Avatar
Massachusetts
Images: 18
I just finished building custom partitions, shelving and a tool box in the back of my truck under the cap using the pre-formed slots in the bed liner. The whole thing is made of two by fours and two by sixes which slide into the bed liner grooves. I got tired of all the camping gear piled on top of each other in disorganized heap which only got worse during the duration of the camping trip. I even have a custom space with a hinged lid near the tailgate in an easy to reach location to hold the hitch, grease, and weight distribution bars. Everything is easily removed if I need the space to carry furniture or something else that is large and warrants the removal of the partitions.
WBCCI Region One
Old 02-24-2007, 08:19 PM   #13
yukionna's Avatar
Massachusetts
Images: 18
I just thought of something else we always pack -- a roll of velcro or, to use the proper parlance, "hook and loop"!
And a pair of scissors.
WBCCI Region One
Old 02-24-2007, 08:21 PM   #14
myboyburt's Avatar
1993 25' Excella
Full Time , Anywhere USA
Images: 12
I pack Leon.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Airstream vs. Avion? 68 Suburban Vintage Kin 29 11-21-2008 07:35 AM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 01:39 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
