Old 02-10-2004, 06:01 AM   #15
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Hahaha
Sounds like you have your work cut out for you Cedars.
To put the size in perspective....a Suburban is pretty close to 20ft so that bus is not really all that huge. It's wide and it's tall and makes you think it's a lot longer then it is.
Sounds like you have some good ideas of how you want things. Just put some thought ot safety aspects. You probably want to add some seating with Belts for passengers. Might look around and see if some RV captains chairs with seat belts pop up.
Heating and cooling is going to be the trick. Put some thought to upgrading the insulation. Limiting air leaks would also go a long way.
Is this a slab side like a school bus or it is more of a fancy bus like they use as airport shuttles?
If it's like a school bus then it's quite easy to remove windows and cover over the holes. Not bad to cover the complete ise where the windows go and convert to a RV style windo like you would find in a Motor home. Take a litte of the "Short Bus" look out of it and get the windows where you want them.
Cooling is the easy part since you want to carry the generator on the bus. Just throw a roof mount on it. Heat strip might be enough if it's insulated well. If not there are heaters available that will make heat using the coolant from the engine. Down side is if you go that route then you will need suplemental heat for when it's parked.
Here is the site about the heater set up I was talking about.
http://www.ki7xh.com/campheat.htm
That is just so slick for use on anything with a motor. That would give you heat in the cabin and pre warn the engine if the bus is a deisel and could be used for hot water if you ever decide to plumb the bus. Now this guy is into gagets so he has made it a little more complcated then it as to be but the timer is a nice feature especially if you use this to preheat the engine.
As for the generator. Put a acess door on the side into your storage compartment in the rear. Build a box to seal it off from the rest of the coach. Quick connects so you can pull it out as needed. Just need to incorperate a slide to get it out. Fair warning, Generator big enough to run the A/C and some other interior stuff is going to be around 125lb for a light one.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-10-2004, 06:37 AM   #16
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally posted by 59toaster
Site would nopt let me link.
This is my idea of our next pull rig.
Hey toaster, all that thing needs are some .50 cals on it and a few rocket launchers....other than that pretty cool tow rig!
Old 02-10-2004, 07:10 AM   #17
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Ya think? hehehe
here is what it would have looked like before they made it a camper. It is a old German Army truck just like this. Note the Gunners hatch in the roof.
http://www.eurotruck-importers.com/i...W1300L2330.jpg
Main listing for this truck and yes it's local to me and yes I'm scraping pennys like never before
http://www.eurotruck-importers.com/dieselmogs.htm
1959 22' Caravanner
Atlanta, GA
Old 02-10-2004, 07:15 AM   #18
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Just think what you could then do to the next guy that cuts you off in traffic!
Old 02-10-2004, 07:20 AM   #19
Aluminut
2004 25' Safari
. , Illinois
Sure makes the Hummer seem humble!
