Old 02-04-2016, 10:03 PM   #1
2004 22' Safari
Albuquerque , New Mexico
What wheel bearing seals???
I have a 2004 22 foot Safari and need to figure out how to determine the part numbers of the wheel bearing seals for this two axle, four tire unit. Any ideas?
Silver.Sanctuary is offline   Reply With Quote
Old 02-04-2016, 10:06 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
You need to know if it has 10" brakes or 12" brakes, then the seals are available at any RV parts house. You want double lip seals.
Bill
Just my personal opinion
Old 02-05-2016, 04:37 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You will need seals for the 10" brakes.
Old 02-05-2016, 05:13 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
The old seals & bearings have numbers on them that can be cross-referenced...., take them to the parts store & match'em.
POI....Don't settle for a 'single' lip seal. Two is better.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 02-05-2016, 06:20 AM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Redneck PN 10-36 for a double lip seal.
Lance
Top is offline   Reply With Quote
Old 02-05-2016, 11:09 AM   #6
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Our 2005 double axle 22 footer uses standard 3500 # hubs with 10 inch brakes. 5x4.5 lug pattern wheels .
Any parts house worth it's salt will have them or can get them .
E trailer online has them as well .
dannydimitt is offline   Reply With Quote
Old 02-05-2016, 11:19 AM   #7
1977 31' Sovereign
Lynnwood , Washington
FYI - Trailer axle seals, wheel bearings, and brakes can be identified by casting numbers on drums or rotors. Trailer parts/supply houses (ie; Six Robblees' in metro-Seattle) do this all the time.
Rule of thumb = When there's a will, there's a way.
Tom
TomKirk is offline   Reply With Quote
Old 02-05-2016, 08:28 PM   #8
2004 22' Safari
Thanks to everyone for the help. I will use etrailer.com as it is far cheaper than the local Airstream dealer.
Old 02-06-2016, 06:22 AM   #9
But probably not as cheep as your local NAPA or bearing supply...plus you have the added benefit of inspection to determine quality....quite a bit of sub-standard out there.
I wouldn't scrimp over price, keeping the assembly intact is important.
PFC
RLC
Wheel bearing seals Craig Schrader Wheels, Hubs & Bearings 1 11-27-2013 09:04 AM
Wheel! bearing seals - 1966 Mike_cfi 1965 - 1969 Globetrotter 5 07-07-2013 07:11 PM
Wheel bearing seals steveirving Wheels, Hubs & Bearings 4 07-03-2013 05:14 AM
16' CCD Wheel Bearing & Seals Part Numbers RDM16CCD 2005 and newer - Bambi all models 0 05-21-2009 04:37 PM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
