Old 12-31-2012, 07:57 PM   #1
1977 Argosy 24
Milltown , Wisconsin
What were the AS engineers thinking?
When they lapped the interior aluminum sheets in the shower the wrong way so the water runs into the insulation. Kind of like shingling a roof backwards so the water runs under all of shingles instead of over them. They also did this with the belly pan on my Argosy. Also they didn't put any bracing under a large area of the bathroom floor. So it became warped and springy. I'm sure the rest of you have a few "What were they thinking's" to add to this..... so pile them on.
ventport is offline   Reply With Quote
Old 12-31-2012, 09:18 PM   #2
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Simple. Don't put non marine grade waterproof particle board (or any non marine grade plywood) in any airstream.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 12-31-2012, 09:29 PM   #3
The correct over lapping has always been followed by Airstream and Argosy production, in the interior.
Perhaps a previous owner took some things apart.
Old 12-31-2012, 10:32 PM   #4
1977 Argosy 24
Not likely, even the vinyl on the aluminum is trimmed off at an angle and the factory rivets were all in place on the top piece. It all looked factory and un molested.
Old 01-04-2013, 04:25 PM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'm guessing they were in a hurry on the production floor. The engineers designed it correctly, but the new guy screwed it up on installation, and the inspector just told them to put extra caulk on it and let the dealer fix it when it was brought in under warranty.
Old 01-04-2013, 07:18 PM   #6
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
My 73 Argosy has the interior skin overlapped the wrong way also. The interior skin has never been touched. On my to-do list is to adequately seal those seams before we use the shower.
DryFly is offline   Reply With Quote
