Old 10-07-2009, 04:14 PM   #15
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Last time I was at the factory, I asked the service techs about the foam in place insulation. The response - "Most crumble, but some may be OK.... until you have to replace a segment or panel. It sticks to EVERYTHING and almost doubles the labor cost to remove a panel. If we KNOW it's under there, we recommend just laying another piece on top of the damage and fastening it with aluminum rivets."
Paula
Old 10-07-2009, 04:25 PM   #16
VIKING's Avatar
Boulder Creek , California
Hi Paula,
This is not spray-in foam, but flexible polyurethane foam with reflective foil on both sides. It gets cut to size and taped in place. I have heard enough bad stuff about the spray-in to stay away from it. If you're interested in researching it more look at www.insulation4less.com It's called Prodex.
Thanks, Rich
VIKING is offline   Reply With Quote
Old 10-07-2009, 05:00 PM   #17
pbearsailor's Avatar
Port Hadlock , Washington
Originally Posted by VIKING View Post
I purchased 700 sq.ft. and it barely covered my 22' safari with 2 layers. Keep in mind that I have more windows-per-foot than most(9 total), so you should adjust your figures accordingly. Also, get the tape from them. It was a better deal than I could find anywhere else.
Rich
Rich, I've been planning prodex as well and put the order in this morning. Thinking about the double layer like you did, especially with your info that the one roll did your Safari. Can't really tell from your pics, did you run your wiring in the airspace between the two layers?
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 10-08-2009, 12:03 AM   #18
VIKING's Avatar
Yes, that's exactly how I did it. I'll try to post some pictures of it if I can find some decent ones.
Rich
Old 10-13-2009, 07:11 PM   #19
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Are you also using Prodex under the floor?
Birdwell57 is offline   Reply With Quote
Old 10-14-2009, 08:15 AM   #20
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I used rust-proof 'Monel' staples and Vulkem to install Prodex under the floor - a border strip two-inches wide around each panel, and a two layer Prodex center standoff to add more air gap and provide drainage if water ever gets between the floor and insulation.
I plan to add blankets on the spars stitched on with ty-wraps before it gets closed up.
ID:	88939   Click image for larger version
Name:	RRtiesand blocks.jpg
Old 10-14-2009, 08:46 PM   #21
VIKING's Avatar
I plan on using sheets of polyurethane foam to fill the cavities under the floor completely. It can double as a raft if it keeps raining like this. I just need to find that old outboard motor...
Old 10-14-2009, 09:42 PM   #22
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
You mean you don't have a pair of wooden oars? SHAME..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 11-12-2009, 06:51 AM   #23
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Is one layer of prodex enough for the underbelly? How did you use it in the banana wrap? Or did you use something else in that area?
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-12-2009, 11:44 AM   #24
Wabbiteer's Avatar
1972 29' Ambassador
Prodex in a floor is excellent in a cool or cold weather climate - its not so good at keeping heat from rising into the floor - specs from website:
heat flow down (1) layer of Prodex *R 15.67
heat flow up (1) layer of Prodex *R 6.00
The specifications on the prodex website are with 2 & 2/3 inches air gap. Thats easy to do on a stick built housing structure but hard to do elsewhere.
Prodex - and all reflective type insulation - work especially well at reflecting heat 'upward' and cold 'downward' - the important part to remember is it needs a dead air space to truly work.
When heated energetic air molecules slam into the aluminum its got to be reflected back without imparting much heat energy and a large air gap reduces the number of times it can ricochet around, multiply that by billions & billions of nitrogens and oxygens and you see what the score is.
I put prodex in primarily since it does not provide aide and comfort to rodents - and left the air gap intentionally small at 1/4 to 1/2 inch to keep little vermin condos out of that air gap.
The spar area was done the same way - two inch strips around the exposed plywood area edges glued on with vulkem and then the outer shield of prodex glued to those, with a double thickness standoff in the center, then tacked for a mechanical fastening with the rustless monel staples.
It's tempting to go with another layer, of prodex of something else in the subfloor area but the real deal to worry about is the roof and walls, which I have not closed in yet...
