Old 01-10-2016, 09:48 AM   #29
Gainesville , Florida
Isn't checking the roof each year part of normal maintenance? Something I am lax on doing.
Old 01-10-2016, 09:49 AM   #30
richw46's Avatar
Lexington , Kentucky
Originally Posted by Buzzr View Post
It looks like I am going to have to do some reading to learn how to post pictures.
There are 2 buttons / options available to you in the reply; attachments (paper clip) and insert image (yellow with mountains). Attachments are from your hard drive, browse for them, then upload. They count towards your forum upload limit.
Insert Image is for linking to images elsewhere on the Internet. I have a free account on www.flickr.com/. Posting from there is more complex so if you're not web savvy you might want to find another site. Anyway, you just need to insert the link to the image in your reply and it doesn't count as part of your forum upload limit.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 01-10-2016, 09:56 AM   #31
Blacksburg , Virginia
Thanks Rich. I see that now. I was using quick reply.
Buzzr is offline   Reply With Quote
Old 01-10-2016, 10:05 AM   #32
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I was told by JC to expect a full day or a little more for the roof job, at $1000 per day. My expectations are 2 days for what I want so I am already prepared to pay that much.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-10-2016, 12:16 PM   #33
1998 30' Excella 1000
Livingston , Texas
Originally Posted by richw46 View Post
Hi Larry, we had our 23' pressure tested and the rain test. We also had the roof seams cleaned and resealed. It took 8 hours for the reseal and the technician said it's best to have it done every 3-5 years. .
I'm still surprised at this issue related to roof seams. Roof penetrations, yes, but seams? As I understand it, most of the sealant is between the overlapping aluminum sheets under the rivet line and not exposed to weathering. My '98 has never leaked at a roof seam, and I annually inspect them testing to see if they will wick water.
Has anyone had pressure testing done that revealed a leaking roof seam?
Siegmann is offline   Reply With Quote
Old 01-10-2016, 12:41 PM   #34
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I don't believe that the factory seams of the aluminum sheets themselves are ever addressed - they are sealed for life. (Unless you need to replace a panel due to hail damage or what have you)
It's all the other caulking around external components / where the roof has been cut in order to accommodate the air conditioner, Sky light, etc... That caulk breaks down due to exposure to the elements over time and has to be removed and re-sealed to avoid water penetration.
I think I paid somewhere between $1k and $2k last time I had this done at timeless travel trailers here in Denver. Preventative maintenance. My trailer is 8 years old now so I think time for a second go around.....
wulfraat is offline   Reply With Quote
Old 01-10-2016, 01:35 PM   #35
lsbrodsky's Avatar
The lengthwise seams are not on rivet lines and the sealant bead is much bigger. Those are the seams that are beginning to crack. The vent sealant has already required touchup.
Larry
Old 01-10-2016, 03:13 PM   #36
Livingston , Texas
They must have changed the way they construct the roof. My lengthwise seam on the roof has rivets about every inch.
And I'm still curious if this recommendation for caulking of roof penetrations every 3-4 years is a function of the new caulk they are using. As I've mentioned before, my original factory caulk job looked good for up to 10-15 years (depending upon the component).
Old 01-11-2016, 09:53 PM   #37
Livingston , Texas
Larry
The more I think about this the more it puzzles me. This comment came from a member who owns a 2012 25' FB International and was talking about the roof seams. Are they really building them with a seam between two aluminum sheets that are only held together with adhesive/caulk?
Old 01-12-2016, 03:35 AM   #38
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Or was he describing the sealant where the awnings are mounted?
SeaLevel is offline   Reply With Quote
Old 01-12-2016, 04:31 AM   #39
lsbrodsky's Avatar
I am sure I am wrong about the rivets, it is too cold to take a ladder out there now. But I do know that the lengthwise beads of caulk on the top of the roof are wider and bigger than the crosswise beads.
Larry
Old 01-13-2016, 01:39 AM   #40
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Airstream adds an eight or ten inch wide panel to the roof sheet metal as they are unwilling to order sheets the proper width for the trailers. So that seam is the full length of the white roof.
Old 01-13-2016, 08:02 AM   #41
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Also noticed that on mine. I have never understood why Airstream refuses to address the inherent leak potential of piece meal assembly of the roof. Why not not us a single panel and wrap it down the sides? The result would be a minamizing of the leak potential.
MICHAEL
Old 01-13-2016, 09:42 AM   #42
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Is it because Airstream is unwilling to order wider sheets or because Alcoa is unable to provide them, as I understand it. I know some folks dislike Airstream's processes, but really . . .
Doug and Cheryl
Should I buy or should I run away ddruker Ribs, Skins & Rivets 16 04-15-2012 10:35 AM
23' to 25'FB? Should have listened! starflyte1 Off Topic Forum 28 08-12-2007 08:04 AM
Should we or should we not Angel73 Floor Finishes 12 03-18-2007 08:48 PM
Should our TV have an Isolator Installed? wheel interested Batteries, Univolts, Converters & Inverters 6 11-28-2006 10:18 AM
Should I have dumped my fresh water? wacnstac Fresh Water Systems 9 05-30-2006 08:28 AM
