Old 02-23-2011, 07:49 PM   #1
Eric Johansen
1976 31' Sovereign
San Francisco , California
What should I do before moving an AS Trailer
Just bought a 1976 30-ft Soverign that has been sitting on blocks for 12 years in Texas. I will tow it just 3 miles to my brother's for a complete restoration. The tires appear in very good shape and are holding air. My concern (hence the question) is about the axles and wheel bearings. Can I reasonably tow it just three miles without servicing, or should I pull the wheels and pack the bearings and lube the axles?
Thanks in advance for your help.
Eric Johansen
EricJohansen is offline   Reply With Quote
Old 02-23-2011, 08:03 PM   #2
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
At the very least pull the hubs and grease the bearings. It doesn't take a whole lot of time and 3 miles will ruin the bearings and possibly the spindles if they're dry.....Cheers.
pgr32e is offline   Reply With Quote
Old 02-23-2011, 08:39 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I would tow it slowly, very slowly. If the trailer was 'sitting' on those tires for 12 years they are toast no matter how good they look.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-23-2011, 08:43 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
When I bought mine, I only had about three miles to tow it home. I called my insurance guy and got an insurance binder. I just checked that I had the right hitch ball, that the brake lights and the signals were working, and the brakes worked. Mine was licensed and had been used but not maintained. My spindles got repacked a month later and were fine. If I had it to do over, I'd do the same.
Old 02-23-2011, 09:02 PM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
The axles are finished at this point anyway so I would just make sure the wheels aren't on the verge of falling off & tow it slowly to its new location. If the bearings feel loose, open them up & figure out what the issues are. If one bearing assembly is too far gone, just leave the wheel off. Airstream's were designed to tow on three wheels for short distances.
Colin
Colin H is offline   Reply With Quote
Old 04-21-2011, 05:45 PM   #6
1972 Travelux Princess 25
Cobourg , Ontario
Make sure the trailer is level on the hitch and the tires pumped up. You are much more likely to blow a tire if the weight is distributed unevenly in other words if the front or rear is sticking up in the air.
If you can borrow a set of wheels and good tires off another trailer, all the better.
If the brakes are iffy it might be wise to hire a tow truck. Shouldn't cost much for such a short move. By that I mean the tow truck from the local garage, that they use to tow in broken down cars. Not the pro mobile home movers.
Make sure the tail lights turn signals and brake lights work. Or, if you get the tow truck he will have temporary units to stick on the back bumper.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 04-21-2011, 06:41 PM   #7
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Open a new catagory in Quickbooks.
Ultradog is offline   Reply With Quote
Old 04-21-2011, 08:07 PM   #8
Ottawa , ON
Old 04-21-2011, 08:14 PM   #9
Splitrock's Avatar
Hahahaha! Been there, done that!
Old 04-21-2011, 08:24 PM   #10
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Made me laugh!
UAPachyderm is offline   Reply With Quote
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
7 Way Trailer Cord aname4me Electrical - Systems, Generators, Batteries & Solar 6 03-09-2011 11:20 AM
How do you deal with your trailer while exploring? mikescha On The Road... 18 02-21-2011 11:36 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
