Old 08-19-2012, 09:21 PM   #1
parrotheadrv's Avatar
1973 29' Ambassador
troup , Texas
What is this vent?
We have a 73 Overlander and located just inside the door to the left at the bottom of the cabinet is a vent that blows air continuously. I've ordered a service manual but i don't have it yet can somebody help me out and let me know what this fan is...Thanks
parrotheadrv is offline   Reply With Quote
Old 08-19-2012, 09:31 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
It's probably your univolt in there. That's where mine was in my '76 Overlander that I used to have. It hums & throws some heat (I don't know if there is an actual fan in yours)
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-19-2012, 09:53 PM   #3
1973 29' Ambassador
troup , Texas
Pretty sure mine is in the rear inside the bathroom closet. There's an actual vent cover on the side of the cabinet, like a 4"x10" and the air isn't really warm. It blows hard enough you can feel it 4-5 feet away.
Old 08-19-2012, 10:45 PM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
This is probably totally irrelevant, but right in that location on our trailer ( which has not much in common with yours) is a furnace vent that blows pretty hard and doesn't put out much heat.
Heck, our trailers weren't even made in the same century.
If the post is of no help, at least it will keep your question on the front page a bit longer,
Ken
Old 08-23-2012, 04:42 AM   #5
rogerdodger's Avatar
Fresno/Clovis , California
On my Argosy, just inside the door, to the left, under the stove, is the propane furnace, vent on the side nearest entry door. Is you furnace fan running all the time? Check your thermostat on the bedroom wall.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 08-23-2012, 04:57 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Got a picture? I believe that will be a furnace vent. Check your thermostat and see if the switch is set for fan "on" rather than "auto".
Aaron
WBCCI #XXXX AIR #2495
Old 08-23-2012, 05:10 AM   #7
Aaron
Ha, Aaron, I beat you to it. LOL
Roger
Air# 29488
Old 08-25-2012, 09:23 AM   #8
1973 29' Ambassador
troup , Texas
It is the furnace and it was running because the wires to the thermostat were twisted together (thermostat is disconnected while working on updates inside). Thanks all
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Stove Vent Motor Speed Control Road Geezer Stoves, Ovens & Microwaves 12 04-29-2011 02:12 PM
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 02:35 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
