07-25-2014, 06:24 PM
1977 27' Overlander
1996 34' Excella
Florida Panhandle
What is this thing???
After we found a leak and removed some of the rotten wood sub floor from our '77 Overlander this canister appeared. We can't see how it is connected or if there are any lines attached to it. We can't see it from underneath without removing aluminum sheeting. We are trying to avoid removing and replacing any additional flooring which would give us a better look at it so I wonder if anyone can tell me what they think it is. It is metal and appears to a tank of some sort was added with straps holding it on. It is about 3 feet in front of where you walk in the door, near the front. Any one have any idea?
07-25-2014, 06:26 PM
2018 25' International
Van Wert
, Ohio
Nope!!!
07-25-2014, 06:28 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
pressure water tank, under the floor rather than above?
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
07-25-2014, 06:29 PM
Oswego
Water system accumulator? Get a mechanics inspection mirror and see if there are water lines back in there.
-Rich-
07-25-2014, 07:47 PM
Retired.
, At Large
Did your trailer have disc brakes? It could be a vacuum reservoir for the booster.
07-25-2014, 07:53 PM
1973 21' Globetrotter
Houston
Definitely not original equipment. If you have one of those articulated inspection cameras, poke it in around it and see what is plumbed into it. I just saw your "floor rot" post, maybe the trailer itself is not the "time capsule", but that thing is!
That hole you have cut in your floor is really big! Note that there are bolts that connect your shell to your frame that pass through your subfloor under the walls. Even if all you want to do is patch that section, you will need to open up the wall in that area to get at those bolts, and you will have to dig into the bellypan as well, to get to the other side of the bolts.
07-26-2014, 11:53 AM
Jupiter
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
07-26-2014, 03:51 PM
1977 27' Overlander
1996 34' Excella
Florida Panhandle
You guys are great. We still aren't sure but when it cools off we'll get all up in there and let you know when we figure it out
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
07-26-2014, 05:23 PM
1966 17' Caravel
Newport
, North Carolina
Alien safe house (airstream) the canister is the self destruct device used to prevent the discovery of aliens (I watch H2). Don't push any buttons please we could have a major issue! My bet is a filter.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
07-26-2014, 05:41 PM
1977 27' Overlander
1996 34' Excella
Florida Panhandle
Haha. That is possible but I'm hoping for the theory it's loaded with $50's!
The Evans' Family
Florida Panhandle
07-26-2014, 05:50 PM
1966 17' Caravel
Newport
, North Carolina
Po was a cartel member and the white powder you find is not talc! Or maybe a back up food supply for the preppers cat!
Cliff
Yes I said that! Or did I?
07-26-2014, 06:20 PM
1977 27' Overlander
1996 34' Excella
Florida Panhandle
We should have an unveiling ceremony when we get to the other end of it....
07-26-2014, 06:35 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Put your camera in the space between the floor and the belly pan and snap a few photos using the flash. You might get lucky and see what's connected.
Looking at the second photo, it looks like there is an access door through the belly pan that is held in place with screws.
Alan
07-26-2014, 06:52 PM
1981 31' Excella II
New Market
, Alabama
It is the flux capacitor silly. It is probably an accumulator to reduce pulses from the demand pump.
Perry
07-28-2014, 04:31 PM
1977 27' Overlander
1996 34' Excella
Florida Panhandle
Of course, it's a flux capicitator! LOL
The Evans' Family
Florida Panhandle
