Old 08-20-2015, 08:45 AM   #1
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
What is this? Sani-flush system?
Went to use the sanitary flush line on my new trailer for the first time and heard the sound of water inside! Quickly stopped before too much damage but did make a small flood.
Trying to investigate the cause and noticed this clear plastic piece? What is it? I believe it's on the flush line. It's open with no top. I suppose it should be covered???
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 08-20-2015, 08:49 AM   #2
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Ugh. Using mobile with suspect 4g. Will have to upload photo later.
Old 08-20-2015, 09:04 AM   #3
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Old 08-20-2015, 09:09 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Where are you seeing this? Step back a bit and send another picture so we can get a better idea of what it is.
I am really interested in what the electrical valve is.
2004 Excursion 4x4
Old 08-20-2015, 09:25 AM   #5
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
The valve on the right seems to be part of the fresh water system. On the left seems to be the sanitary flush? These are the inside of the trailer where the fresh and waste wash inlets are.
Old 08-20-2015, 09:26 AM   #6
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
This is a 30' bunk. The electric valve could be part of the toilet vacuum system?
Old 08-20-2015, 09:56 AM   #7
HowieE's Avatar
Images: 12
Boy you have gone completely beyond me on this one. I can't imagine vacuum, what is the source of the vacuum, being involved with an RV toilet system or an open vent to the black waste system anywhere inside the trailer.
Do you have a manual?
2004 Excursion 4x4
Old 08-20-2015, 10:02 AM   #8
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
The toilet itself is vacuum flush. I don't think that's the issue here.
I think that clear plastic piece is from the tank flush line. But it is completely open?!? I imagine it should have a top. Really no matter what water line it's on unless it is a vent of sorts.
Old 08-20-2015, 10:32 AM   #9
1996 25' Excella
Tillsonburg , Ontario
Looks a bit like a shower back flow preventer/vacuum break....but it should have a cover on it
I saw something like this on an SOB 5th wheel tucked behind the Mirror glued to a wall
JCW
JCWDCW is offline   Reply With Quote
Old 08-23-2015, 07:02 AM   #10
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I will try to get more pics up but this is behind drawers about 3' above the floor. Maybe 8' from the shower.
Old 08-23-2015, 07:20 AM   #11
dznf0g's Avatar
Oswego , Illinois
It is the backflow preventer with the cap and valve completely blown off. The valve is RVIA code (I assume). The cure is to remove and replace with pex line. Very common failure and will happen again sooner or later.
-Rich-
Old 08-25-2015, 07:02 PM   #12
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Thanks. Backflow preventor from what line? I suspect it is from my black tank flush line? Is that why I got all the water spray inside? Maybe there was too much pressure?
Old 08-25-2015, 07:18 PM   #13
dznf0g's Avatar
Oswego , Illinois
Yes from your black tank flusher.
-Rich-
Old 08-25-2015, 07:50 PM   #14
2015 30' FB FC Bunk
Ayer , Massachusetts
It makes sense that there is a backflow preventer between the tank flusher a water supply. I would assume the missing part is somewhere in the cabinetry near by?
Anyway, I have the same trailer. I use the tank rinser by closing the blank tank knife valve, turning on the water to the tank rinser and filling the tank to 75-80%, then opening the knife valve and dumping the tank. Then repeat.
I have never had an issue, so that should confirm somthing is amiss on your trailer. Did you buy from Colonial? They should be able to help out.
Ted S. is offline   Reply With Quote
No fuss flush black tank rinsing system" lloydnc Waste Systems, Tanks & Totes 21 04-22-2013 05:44 PM
Sani-Dump Tips, Clipper, Class A, Land Yacht masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 09-06-2012 10:19 PM
Sewer Flush System blocked... KIMILI Waste Systems, Tanks & Totes 14 08-31-2004 03:15 PM
How to add a b/tank flush system inthwind Waste Systems, Tanks & Totes 2 06-25-2003 09:59 AM
Black Tank Flush System Ed & Nancy Our Community 6 02-19-2003 08:36 AM
