Old 08-28-2015, 09:12 PM   #43
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
The one bad battery could have an internal short, it doesn't mean the converter is the at fault..with 2 airstreams and 1 avion, I have never replaced the converters, my batteries lasted about 5 to 7 years, you just add a little distilled water to the batteries a couple times a year...
Old 08-28-2015, 09:22 PM   #44
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Ntex - the only truly sealed batteries are AGM's (absorbed glass mat), which generally sell for $300 to $400 each. The most likely underlying cause of the failure is the OEM charger/converter which is a single-stage one. The preferred solution is to upgrade to a multi-stage charger/converter. It is not a very costly venture; many have done it and there are numerous threads on which one to choose and how to swap it in in place of the single-stage one you currently have. More than likely what you are going to pay for replacing both batteries is greater than what you would pay for a new converter.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 08-29-2015, 12:50 AM   #45
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Well at least Lander is a fun little town! The pioneer museum north of town is a good time killer! People are very friendly. Several things to see and do!
Lets hope you aren't sidelined too long!
Best of luck
Old 08-29-2015, 04:39 AM   #46
2009 27' FB International
Silsbee , Texas
Like others have said, do not assume it was the battery that caused the smell. Check all the LPG fitting that you can get to with a spray bottle filled with a soap solution. If leaking it will blow bubbles. Just start at the tanks spraying regulator and follow the copper tubing into the trailer. Piece of Mind is priceless.
Craig Schrader is offline   Reply With Quote
Old 08-30-2015, 08:05 PM   #47
2002 31' Classic
Houston , Texas
NTEX:
Well, there may be a VERY simple answer to this situation.....
From your posting of 8-26, perchance was there a complete draining of the propane in one (or both) of the tanks? There is usually a collection of liquid(s) at the bottom of most tanks (teaspoons, maybe) that are usually undisturbed; they contain methyl mercaptan in a more concentrated state. When the propane (which is liquid) gets very near the bottom of the tank, the concentration of stink-um gets quite high, and the odor of the combustion gasses gets REALLY strong. If you smell that unexpectedly, simply change tanks.
Lemme know, please? I'm kinda surprised this hasn't been suggested before by someone else.....I've had five trailers, four of them Airstreams, in the last forty years, and it's been a characteristic of every single trailer when a tank runs out.
Kent
Houston
KMarshall is offline   Reply With Quote
Old 09-01-2015, 10:53 AM   #48
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Just to throw another possible source of sulfur smell into the mix. The water heater can be a source.
The smell is created when natural sulfates found in some water mix with certain micro organisms (bacteria), they produce hydrogen Sulfide (H2S).
To my nose, propane smells nothing like sulfur.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Obnoxious Creak jeff4506 Repairing/Replacing Floor &/or Frame 19 03-05-2014 08:13 PM
sulphur smell pbarstow Furnaces, Heaters, Fireplaces & Air Conditioning 14 07-16-2010 08:45 PM
Will Adding a Front Rock Guard Set Make Our Argosy too Dark inside? AndyPenny All Argosy Trailers 5 03-27-2008 07:00 AM
Low sulphur vs ultra-lo sulphur diesel? ScottW Tow Vehicles 24 02-27-2008 02:35 PM
Inspector needed Sulphur Springs, TX (near Dallas) bstjames Trailer Values 2 11-25-2007 03:25 PM
