Old 05-17-2009, 04:07 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
What is this nozzle fitting?
I found this garden hose type nozzle on trailer in middle of the hitch has a cap on it . It would fit a garden hose on it no valve .
Is this a drain of some sort?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 05-17-2009, 07:21 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
It might be for water hose at a campsite with a water hookup. My '74 Argosy had a threaded plug on a lanyard to block it while underway. Got a picture?
5 meter Langford Nahanni
Old 05-17-2009, 09:11 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
If it is on the 1977 Sovereign, it may be the Vacuum Port for the Excella HydraVac Disc Brakes. It could also be a fixture added by a previous owner to fill the fresh water tank.
Kevin
Kevin D. Allen
AIR #827
Old 05-17-2009, 09:35 AM   #4
1977 31' Sovereign
Images: 33
Kevin
Ok I bet it for the old brake system because I filled the water and the cap was off no water leaked out.
K/N Cool intake air
Duel power exhaust
AS MotorHome fuel nozzle problem Vickig46 General Motorhome Topics 13 05-29-2009 03:03 PM
Thetford fitting goransons Waste Systems, Tanks & Totes 0 04-28-2008 07:19 PM
Fitting new converter Skater Batteries, Univolts, Converters & Inverters 8 03-14-2008 03:19 PM
Help! 1/2 x 3/8 x 3/8 push fitting glacierrunne Fresh Water Systems 7 06-05-2006 10:04 PM
Toilet Spray Nozzle Leak DaveJ Sinks, Showers & Toilets 1 10-12-2003 12:29 PM
