I have had this leak reoccurring under the fridge on the right for some time. I called airstream and they said check the drain tube coming out of the back of the fridge.
I did check it on the outside and moved the end of it to make sure it was going out of the trailer and not rolling back in and under the floor. When I adjusted it it was dry, so I'm not entirely sure it was going back inside and under the floor - just a hunch. Checked it today and it was indeed dripping outside of the trailer and not rolling back in (at least today). BUT, there's also still a big puddle under my fridge.
So, either it's somewhere else on the drain tube (the back of the fridge?) or it's something else completely. I've ruled out rain.
I'd like to know if anyone else has had this same leak (what is it?) and/or if anyone knows how to pull the fridge out of a 2015 International Signature (30ft)?
The water on the floor is here:
https://www.flickr.com/photos/laural...posted-public/
I moved the drain tube out about an inch to reach the gully on the outside, just to make sure it's draining out:
It's not evident how to pull the fridge out to get behind it:
