Old 07-24-2016, 12:34 PM   #15
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Originally Posted by A W Warn View Post
What it looks like to me:
Something has cracked the valve, freezing or road debris.
You are going to have to replace that valve.
ps:
Someone has already replaced those valves. The original valve would have been one of these:
http://odmrv.com/catalog/index.php?m...roducts_id=533
I think these are a better choice for that location.
Did you winterize or was it the dealer?
If this isn't the first trip for the year, I would suspect road debris. Personally I would fabricate some sort of metal guard. These are very exposed and I suspect will continue to have a target on them.
Even the FW tank drain has a (rinky dink) guard
CruizinDux is offline   Reply With Quote
That darned leak!! Need help from leak experts !! nickclifford General Repair Forum 20 12-03-2015 06:52 PM
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 02:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 09:46 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 11:52 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 07:28 AM
