Old 02-08-2004, 10:48 PM   #29
Send a message via AIM to rochsmama Send a message via Yahoo to rochsmama
thank you! pahaska
It sounds so reasonable, my face is red!
Thanks again!
rochsmama is offline   Reply With Quote
Old 02-09-2004, 10:44 PM   #30
What a treat!
Read all comments and guesses, it was thrilling!
Fabofabo
fabofabo is offline   Reply With Quote
Old 02-10-2004, 07:23 AM   #31
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Burglar Bar
I just thought of a third use for it.
You can use it to fend off uninvited guests in your trailer!
Old 02-10-2004, 07:44 AM   #32
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: I have the dual cam with u bolt
Originally posted by rochsmama
how do you determine the correct link in the chains to hook before you raise and lock the weight distribution bars? Is it just a trial and error until you get the right combo that controls the best?
http://www.reeseprod.com/index.htm Is the main Reese web site. If you click "Suport" then page that pops up has links to PDF Istructions on their products
http://www.reeseprod.com/support/sup...fs/66006IN.pdf
That gives some good tips on how to adjust a WD hitch properly.
It is a little trial and error and qulity time with the tape measure like Pahaska said . But once it's set and you use it a few times you will know what to look for.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-11-2004, 04:50 AM   #33
baldeagle's Avatar
Strange Tool
It is the tool used with the equal-i-zer hitch. It is used to lift the bars onto the A frame mounted saddles if you cannot get the hitch jack high enough to just slide the bar on. Just started using this hitch with my 2002 31' and i am pleased with its performance.
baldeagle is offline   Reply With Quote
Old 02-11-2004, 08:26 AM   #34
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Re: Final word
Originally posted by Pahaska
It is an Equal-izer hitch optional snap-up lever, part #1104. Look at the Equal-izer Assembly Instructions . Go down to figure F and you will see a line drawing of the tool in use. If you can't jack the tongue high enough to put the bars in the brackets by hand, you simply snap them in with the tool.
baldeagle
As you can see, this has been answered several times earlier in the thread.
John W. Irwin
WBCCI #9632
Old 02-11-2004, 12:52 PM   #35
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Last final word
It's Wally Byams magic wand.
AirForums Custom Search
Janet H is offline   Reply With Quote
