Old 02-02-2004, 03:20 PM   #15
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
Cool! Great work! I wish I had a reward for you other than thanks.
Now knowing that it is from the E-qualizer hitch, which I didn't know I had, I realize that I must have a very old one. The PO gave me everything but the actual hitch/shank. Also, the place they attach to the tongue looks very different. There is no L-bracket.
I'll have to post more pictures. I was planning on purchasing a new E-qualizer hitch, but if I can get parts, that should save me a few bucks!
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 02-02-2004, 05:19 PM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Exclamation I knew that!
Man I knew I shouldn't have gone to work today...I could've won...I know I could. BTW here is a picture of the current tool.
Aaron
Name:	hitch tool 2a.jpg
WBCCI #XXXX AIR #2495
Old 02-02-2004, 07:28 PM   #17
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
what it is
It's obviously a backscratcher.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 02-03-2004, 02:30 AM   #18
Hello! Its a shoe horn...duh!
biggerbadbrad is offline   Reply With Quote
Old 02-03-2004, 07:16 AM   #19
I got my new hitch and it had one of those in the box, it was in two pieces so I had to bolt it together, it is a tool for putting the bars up on a E-qualizer hitch.
Gene Wissink is offline   Reply With Quote
Old 02-03-2004, 10:38 AM   #20
It can also be used to remove "hub caps."
Old 02-03-2004, 10:45 AM   #21
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
I've been using it to pick my teeth after BBQ'd ribs. <--see how clean?
Old 02-03-2004, 11:02 AM   #22
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
I have one of those (came with the hitch), but I don't bother bringing it with me. Instead of prying the Equal-i-zer bars up with the tool, just crank the front jack up until the bars slide on easily.
-- RL
rluhr is offline   Reply With Quote
Old 02-03-2004, 04:24 PM   #23
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
Ok, now that we have had some fun with that part, and I now know that it is from an old E-qualizer unit, the following are the rest of the components I have. I don't have the hitch part, and am curious if it is worth it for me to try and find it, rather than buy a new E-q.
Old 02-03-2004, 05:06 PM   #24
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
You have bars from two totally different hitches. The snap-up bracket could be used with either set of bars. There is also a ball on the tongue for a friction sway bar which you apparently don't have either.
My choice would be to go with a DrawTite/Reese HD dual-cam since I am not a fan of the Equal-izer. The snap-up brackets would still work fine , but the rest of the parts in your photo would be history. The sway bar ball could stay on the tongue (I have one unused on mine).
I have towed enough with my HD dual-cam to really appreciate its performance in heavy crosswinds and truck traffic. As a side effect, I have found that it makes backing the trailer easier since the trailer tends to track straight hands off.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 02-03-2004, 05:11 PM   #25
J&C
J&C's Avatar
2002 31' Classic
Hillsboro , Texas
Images: 11
Sounds like a segment of THIS OLD HOUSE
J&C is offline   Reply With Quote
Old 02-03-2004, 06:59 PM   #26
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
What is this?
Greetings Sneakinup!
I agree with John in regard to the Reese Dual Cam. I am a bit more inclined to favor the original Dual Cam with U-Bolt attachment for Vintage Coaches as it makes me uncomfortable to think of drilling any additional holes into the "A" frame of the hitch on a Vintage Coach. I have the standard Dual Cam with the U-Bolt attachment method on both my Minuet and Overlander and am thoroughly pleased with its operation - - in fact with the original style Dual Cam system, the weight distribution bars in your top photo could be utilized with just the addition of the saddles - - a direct bolt-on replacement for the chains - - the weight distribution bars that came with my Minuet are very similar to the ones in your photo and it only took about an hour to install the saddle when I added the Daul Cam system to the Minuet.
Good luck with your hitch decision!
Kevin
Kevin D. Allen
AIR #827
Old 02-08-2004, 09:37 PM   #27
Send a message via AIM to rochsmama Send a message via Yahoo to rochsmama
I have the dual cam with u bolt
how do you determine the correct link in the chains to hook before you raise and lock the weight distribution bars? Is it just a trial and error until you get the right combo that controls the best?
rochsmama is offline   Reply With Quote
Old 02-08-2004, 09:54 PM   #28
Pahaska's Avatar
Hays County , Texas
Following the instructions in the manual for my truck, I measured the height of the rear fender well unloaded, then picked a chain location that returned the truck to that same height.
First, though, you must set the ball at the proper height which you will find in the manual for your trailer. If you don't have the manual, level the trailer frame and measure to the top of the ball cavity on the trailer hitch.
John W. Irwin
WBCCI #9632
