Old 01-07-2016, 05:29 PM   #1
2004 19' Bambi
Cincinnati , Ohio
What is the best sealent for roof seams?
I have a roof leak & need to seal it outside in cold wet weather.
Richard Kern is offline   Reply With Quote
Old 01-07-2016, 05:37 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I like sikaflex 721 or 221
Trempro 735 is good too.
You can order both on amazon
Matt
rugjenkins is offline   Reply With Quote
Old 01-07-2016, 05:38 PM   #3
rugjenkins's Avatar
1975 Argosy 28
Clean, dry and apply
Matt
Old 01-07-2016, 05:42 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Not if you want it to stay put and do it's intended job. Surface prep is key, just like painting a car.
Clean and dry to start, then use either mineral sprits or my fav….carb cleaner but NO ALCOHOL for polyurethane or silane terminated polymer based sealants.
Apply between masking tape if you want a neat job and remove the tape immediately. Clean up with mineral spirits. Practice before starting, as when properly applied, it is NOT easily removable!!
Old 01-07-2016, 05:47 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Acryl R or Parbond will penetrate a small opening in a seam better than Trempro 735.
There are other more liquid sealants that will draw into smaller openings.
Alan
A W Warn is online now   Reply With Quote
Old 01-07-2016, 09:40 PM   #6
rugjenkins's Avatar
1975 Argosy 28
That's what I said, just not in so many words😜. My thumbs get tired 👍
Matt
Sealent for furnace exhaust vent Dan Clayton Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-07-2011 06:13 AM
Baggage compartment sealent tonyp Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 01-15-2011 03:22 PM
Squarestream Roof Seams Sealing ronkat All Squarestream Trailers 1 11-07-2010 09:00 PM
Parbond or Gutter Seal for Exterior Seams??? mwmoss Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 02-23-2005 08:36 AM
Split awning seams APB Awnings 4 02-10-2003 09:34 AM
