10-31-2008, 08:29 PM
Tallahassee
What is that odor?
We just bought a used 2002 25' Safari and now that we have it home, we find it has an odor that we cannot find the cause for. If the air conditioner is on continually, it is not as detectable, but when it has been closed for a day or more, and you open it up, the odor is so noticeable. It does not smell like the black water tank - we were told that the trailer had water damage in the rear and was repaired -- the carpet in the bedroom was replaced with wood laminate. The rest of the flooring is carpet. We bought it from a dealer and we are not sure what to do next nor where to look for origin of the odor. Any ideas?
10-31-2008, 09:10 PM
moderator
2016 27' International
Wilton
Is it the familiar tupperware smell? Mine too.. only if its a bit humid outside and closed up. Disipates once opened up..
08-04-2009, 06:28 PM
banjobill
2000 30' Limited
battle ground,
well phooey, i thought this thread would have a zillion answers-my 85 although looking clean, and with a new a/c new refrig, new faucets, new shower drain, a thorough interior cleaning, still has a slightly "musty" odor in it when closed up for awhile. There is a small (less that 1 foot in diameter) spot in the floor under the street side aft bed (in the storage compartment) that is water damaged. I have not found anyothers as of yet. Could that be it? sticking my nose in it does not tell me that's it. I have water in all the traps...the carpet was replaced.
ah, the odor of a travel trailer....
08-04-2009, 06:57 PM
2008 27' International FB
1999 19' "B" Van Airstream 190
Marietta
, Georgia
We had an issue like this in our older AS. We replaced the mattress and the problem went away.
08-04-2009, 08:50 PM
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
mystery smells
Most smells in a travel trailer usually come from the fabrics and foam. Empty the trailer of all of the carpets, upholstery, curtains and anything else that has fabric or foam and see if the smell goes away. Our '78 Argosy Minuet belonged to my parents who were smokers. We had to strip ALL of the material and foam and carpet out and scrub like crazy to get the smells out.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
08-04-2009, 09:03 PM
Airstream - Other
Bosque Farms
, New Mexico
can you be more specific on the odor itself? If it's not black-water-smell, is it more like musty? Or rotten eggs? Or electrical wire burn smell?
Lynn
ACI Big Red Number 21043
08-04-2009, 09:11 PM
moderator
Wilton
If ours stays locked up and warm inside the smell seems to come from the vinyl / foam ceiling pad. Knowing that I just live with it. If I open it up for an hour or so it disipates.
Vinnie
08-04-2009, 09:30 PM
Vintage Kin
Fort Worth
Agreed about old fabrics, foam, bedding, etc. Especially carpeting and the padding.
Once all done, a thorough wash down of every interior surface with recommended products (factory guidelines?) that is time-consuming and painstaking will "get" most all of this smell.
I went over my trailer top to bottom, inside and out, prior to recent sale, and it took me in excess of 40-hours. Just the interior had to have been over 15 of those hours on that 34' trailer.
In our climate the use of a dehumidifier was near mandatory, IMO. We are all of us so used to HVAC in our homes we forget its role as a dehumidifier all season and that it keeps smells minimized.
Fresh air is hard to beat. Keeping it fresh under particular conditions is an engineering-worthy pursuit (commercial buildings).
08-04-2009, 09:35 PM
St. Cloud
Are you storing in the open sun with the Safari closed up? It's not effective real fast but you might leave some Damp-Rid open when in storage. Usually available at an ACE hardware but also many other sources.
Do you not use the shower during this period? My shower P-trap has gone dry and the resulting gray tank smells are not pleasant. Put a cup of water in all your drains and see if it improves.
08-04-2009, 10:02 PM
Hernando
, Mississippi
Depends on the previous use of the trailer. It could still be 'out gassing' of the materials used in the manufacture of the interior. The vinyls, cloths, etc, give off chemical 'emissions' in the heat. This could be part of your problem. If you can leave the roof vents open just a crack while in storage might help. Just a thought.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
08-04-2009, 10:09 PM
2018 30' Classic
Austin
I know exactly what you are talking about! We noticed it first at the dealership while shopping for a trailer. Walking into new trailers that had been closed up on hot days. It's not a pleasant smell for sure. I can only say that it is similar to the smell after stepping into dog feces. We have replaced the mattress, curtains, foam, and upholstry. It has gotten better, but still is detectable on a hot day. I had previously tried plug in air fresheners, and lots of Febreeze.
08-04-2009, 10:14 PM
1976 Argosy 24
Joplin
, Missouri
Our Argosy had that "old Tupperware" smell, I think from the vinyl wall covering. I put a spice jar (with the lid off) of whole cloves and cinnamon sticks on the counter and now it smells like cinnamon rolls. (Got to be whole cloves because they fairly drip clove oil.)
08-04-2009, 10:30 PM
Salem
, Oregon
Hi, although I haven't had any problems, as Bob said, the traps could dry up and vent; For that reason, I plug both kitchen sink drains, bathroom sink drain, and put the rubber plug in the shower drain when my trailer is in storage.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-04-2009, 11:08 PM
2005 22' Safari
Gresham
, Oregon
We also have an odd odor in our 2005 Safari. Doesn't smell like any black/grey tank odors. But can't really explain it. Plan on changing the upholstery - but dont know if I also need to replace cushions. Doesn't seem like something just a few years old would need to have that done.
08-05-2009, 06:01 AM
2005 19' International CCD
Upton
, Massachusetts
The out gassing new smell could be the problem. We had to cover ours cushions and bed with plastic due to my wife’s chemical sensitivity.
But note of caution this could make them condensate and mold.
Take the cushions and bed out and see what happens.
Mike
