Old 03-16-2016, 09:32 AM   #1
1972 27' Overlander
Lamar , Missouri
What is it?
72 Landyacht, my new retirement vehicle, on drivers side towards rear, above water heater, is a device with 2 screws; there are 2 lights that face forward under the plastic shroud. I took the shroud off and there was 2 wires leading into the trailer. There is a clear lens next to it. They seem to be on after new, as the blue vinyl is cut and pushed back.
Any glues to their purpose?
Thanks for your input.
ID:	258856   Click image for larger version
walleye001 is offline   Reply With Quote
Old 03-16-2016, 09:36 AM   #2
1973 23' Safari
1970 27' Overlander
Boerne , Texas
I believe these are lights (fiber optic?) that are fed by your tail lights. They allow you to see whether or not your tail lights are working. I may be wrong, someone else jump in here if so.
Greg
Greg1410 is offline   Reply With Quote
Old 03-16-2016, 09:49 AM   #3
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
What is it?
That's correct. There are fiber cables that go to each tail light. You can see the turn indicators and brake lights there in the driver's side rear view mirror. Pretty dim so it works best at night. If you take off the brake light lens you should see a small round black gasket with a plastic center behind the bulb. You can get a new cover at Out of Doors Mart or other vendors.
Dennis
dennis3751 is online now   Reply With Quote
Old 03-16-2016, 09:51 AM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Greg1430 is correct.
The fiber optic cables run to the back of the tail/brake light cans.
Vintage Trailer Supply has a cover to replace the deteriorated plastic one.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 03-16-2016, 10:12 AM   #5
cameront120's Avatar
1972 25' Tradewind
And the clear dome to the right of the fibre-optic indicator is a battery polarity check light. Both are original to the trailer.
You can download the 1972 manual from the mother ship's website here:
https://www.airstream.com/service/ma...ear_select=878
North Vancouver, BC
Old 03-16-2016, 10:27 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My Moms Caddy had those on hood and rear "package shelf"... Thought it was kewl in the day!!
We also had those in IBM 3420 tape drives... They faced a filament lamp which cooked the end of the fibre facing the bulb... Lots of intermittent failures resulted.
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-16-2016, 12:07 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The clear light to the right is not a polarity check for the battery(s) it is to check the "so called" polarity of the shore power connection. If the light is on the shore power hot and neutral are reversed somewhere.
