This will be hard to describe without pictures. But we have a shelf rack we like on the counter behind the faucet of the kitchen sink. We've used "museum putty" to keep it on the counter even while traveling and it works, until it doesn't.
DW is 100% opposed to using c-hooks and screws in the counter top. So it dawned on me - we removed the blind on the double windows behind the faucet and the plastic clips on the bottom (where you "park" the blind by popping the plastic pin in to the base of the blind) are screwed in to the wall. So if I could find an item with a plate that screws in to the wall, attached to a fixed (not flexible) shaft which ends in a hook or loop that would wrap around the cylinder at the base of the shelf - it would hold it in place perfectly with no holes to be drilled.
I saw this on Amazon - it's not what I want, but it's similar to what I described. Can anyone tell me what piece of hardware I may be looking for?
Thanks! [emoji3]
https://www.amazon.com/gp/aw/d/B01AR...236_SY340_QL65
