Old 04-04-2013, 02:43 PM   #1
1985 25' Sovereign
kamloops , British Columbia
What do I replace?
Hey I just bought a 1985 25' sovereign. And don't know to what extend I should go replacing stuff. Here's my list.
Axles? It has decent tires and they seem fine
It's got a new fridge
New water pump
New hot water heater
New electronic jack
I got the belly off and it has a couple rotten spots and some rust I'm thinking patch the floor wire wheel or sandblast the frame and por 15
Then I won't put in a new belly cuz I don't see the point ill put in sheet metal over the floor in between the frame and caulk and paint.
Clean up the stabilizer jacks and spare tire rack and put it back on.
Ill buy new batteries propane tanks and maybe update some old lines
I have a sway bar system but no weightbdistribution but I think I'm just gonna stick with that.
Then completely redo the interior. And maybe replace the shower pan or paint.
Would love some advice
sam1991 is offline   Reply With Quote
Old 04-04-2013, 02:49 PM   #2
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
That's a good list! You may find as you start into any of those projects you may want/need to do additional work. (Rarely less!)
Welcome to the forums!
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 04-04-2013, 04:11 PM   #3
New water pump
New electronic jack
The fllowing will help you checking out your axles.
The Dura-Torque Axle
Old 04-04-2013, 07:06 PM   #4
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
I wouldn't tow my 25' without WD
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 04-04-2013, 08:14 PM   #5
mandolindave's Avatar
rule of thumb, first and last
First, Tires (seem to be fine won't cut it ) trailer tires don't wear much. Now you are supposed to change tires every four years. You don't want a blow out.
While you are getting tires, get new bearings and check brakes.
Last....curtains and upolstery
mandolindave is offline   Reply With Quote
