Old 02-28-2012, 12:57 PM   #1
Lfemat's Avatar
2004 25' International CCD
Mexico City , MX
Question What are these things for?
Does anyone know what is the device from the first picture an the box from the second picture?
The device from the first is located in the front of the trailer under the gaucho and the box form the second picture is located jus above the light switch for the exterior light. Both things are placed on my 1970 Safari.
Name:	la foto 3.JPG
ID:	152182   Click image for larger version
Name:	la foto 4.JPG
Lfemat is offline   Reply With Quote
Old 02-28-2012, 01:26 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Neither one looks like original Airstream equipment. Could it be a security alarm of some type?
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 02-28-2012, 01:26 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Freshwater tank system pressure pump and doorbell. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-28-2012, 02:37 PM   #4
Lfemat's Avatar
Mexico City , MX
thank you Ed, the water pump is right beside the furnace under the sink, I think it must be something else. The doorbell has an outside button or how does it works?
Old 02-28-2012, 02:38 PM   #5
Images: 59
Thats an old mechanical siren in the first picture. Open the cover on the second one and someone will probably know what it is.
Old 02-28-2012, 03:47 PM   #6
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
What is the logo in the upper right of the box on the wall?
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 02-28-2012, 03:59 PM   #7
1974 Argosy 20
Kooskia , Idaho
I would guess that both are part of some alarm system a PO installed. They are not original equipment I am virtually positive.
The gray box logo looks like the H that Honeywell used, but it may just be a box someone recycled to a new function.
I doubt that either of these are part of the doorbell system, which may have been an option in those years. If there is a doorbell button, outside, you may find the factory "chime" inside behind a bed. It looks like a home unit, with no cover... two "gong" bars, one for the ding, and dong.
Old 02-28-2012, 04:00 PM   #8
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
second photo sure looks like a honeywell thermostat
alclad is offline   Reply With Quote
Old 02-28-2012, 04:17 PM   #9
Images: 59
Agree that the logo on the second device is 50's to 70's Honeywell. It sure looks like a 1964 GPS receiver, but I think the paper tape printer is missing.
Old 02-28-2012, 04:57 PM   #10
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
The second pic is (as guessed by those before me) is an old Honeywell box. It is in-fact a control box from an oil burning furnace. The red slide type button in the lower left corner was the clue. I also agree the the original contents were taken out and the box used something else. If it is part of the siren alarm system the 2 should have wires connected between them.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 02-28-2012, 05:45 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The second one looks like an old Honeywell flame detector. Some were connected to a thermocouple others were connected to a device called a "looker" and or a "peeper. They were use on industrial equipment like ovens and boilers. They controlled the gas valve for these industrial devices. A PO may have had experience with these units and wired it up for the burner control in the furnace or water heater.
I have worked with many of them in my career. Looks like it is a version popular in the 70's and early 80's.
Maybe the device in the first pic is an alarm horn to wake someone if there was a problem.
Old 03-04-2012, 04:32 PM   #12
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Wake up!
I have seen one of the sirens running. They put out like 150 db.. Not only scare the pouuu out of the person outside,, but the folks inside would also have to restart there hearts..
Sodbust
Sodbust is offline   Reply With Quote
Old 03-04-2012, 04:43 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the first picture is definately an electric motor driven siren and I wouldn't want it mounted there.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-04-2012, 08:40 PM   #14
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Oops!
My original post was supposed to be a question not a statement of fact. I made a puctuation error! I hate it when that happens. Anyway, I agree I would move that siren in the first picture to.... Under the floor and put inside the belly pan as to protect the ears and hearts of the persons that might be inside when it went off. Perhaps the PO that had it installed only activated it when away from the trailer. Sure to get attention if activated. Now if it is a security system one would think some type of sensors would be mounted at door and window locations. Ed
Are Airstreams Gaining Weight? redwoodguy Airstream History 26 03-10-2012 10:29 AM
What are these things for? Lfemat General Repair Forum 15 03-04-2012 09:26 PM
Help me design the ultimate boondocking setup for my MoHo! SteelyDan Batteries, Univolts, Converters & Inverters 13 03-01-2012 08:18 AM
is there turn on valve for gas cooktop? starcraft LP Gas, Piping, Tanks & Regulators 6 02-29-2012 07:45 AM
fuses for 74 trade wind land yacht batt Electrical - Systems, Generators, Batteries & Solar 3 02-28-2012 06:18 PM
