2007 22 FB International CCD with a wet bath.
The Mirrored door for the medicine cabinet on the forward bath wall has pulled off the wall were it was mounted, apparently with just three pop rivits into the fiberglass/acrylic surround. I suspect that the damage occurred when the door latch failed, and trailer vibration helped break the door off the wall. May have been part of the damage sustained when my son had a blowout on the road, and the vibration in that area hit a massive peak...
The middle rivet has torn out a piece of the medicine cabinet wall edge when it departed, and the other rivets have damaged heads where the hinge has pulled off the wall past the rivets.
I'm looking at repairing this somehow, possibly drilling out the remaining rivets, using Bondo or the like to re-contour the damaged area, re-painting to match, and adding more rivets to the hinge to distribute the load better. A better latch is also part of the plan--need thoughts on that as well
Has anyone dealt successfully with this repair, and if so, how? Son says not to bother, but it's a bit hard to shave without a mirror of some sort...
I'm not really wild about attempting to replace the entire top half of the wet bath to solve this--I'm not made outta money...
