Old 04-13-2012, 08:47 PM   #1
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
Weak or no signal
We have a batwing antenna new on the 2008 27 FB Safari. For little or no reason we can think of the Samsung digital tv will no longer receive a good signal... Even in the city. We checked up top and all cables seem to be connected fine. The tv works fine on AV as source for movies. Any suggestions? Also, using a digital converter box on our standard Sony in the back...still getting no signal.
Sammie, Krystal, Lucas, Spencer & Jake!
stowaways is offline   Reply With Quote
Old 04-13-2012, 08:52 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I am assuming that the little green light is coming on when you switch from cable input to the external antenna. The problem may be in the switcher box. Are you getting cable input when the green light is on?
Brian
SuEllyn & Brian McCabe
Old 04-13-2012, 08:58 PM   #3
stowaways's Avatar
1969 31' Sovereign
Ft. Worth , Texas
Moose...the booster is on. That's why this is so perplexing...
Old 04-13-2012, 08:59 PM   #4
stowaways's Avatar
1969 31' Sovereign
Ft. Worth , Texas
We don't have cable...just local hd channels through antenna. Am I understanding your question?
Old 04-13-2012, 10:54 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
We had a signal problem on our Excella. The little green light was on, but our booster was not working. I replaced the booster, and the signal is great. I think the green light only tells that the booster is on, not that the booster is actually working.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-14-2012, 07:01 AM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Coax is not robust stuff. Broken connectors (solder) can account for poor/no signal.
Old 04-14-2012, 07:18 AM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Check and make sure the television is in the "Air" mode. Some of the actual frequencies are different for off air tv and cable. In my '09 the Samsung tv also has separate inputs for cable tv or off air antenna. Make sure you are connected to the correct input.
And, the wall plate with the green light is not actually the "booster". It is simply the power supply for the amplifier that is in the batwing itself. The wall plates can fail, but I have had a relatively new batwing start leaking water and ruin the circuit board up there.
Most tv coax connections are solder free. The "F" styled connector used with RG-6 and RG-59 coaxes employed in tv distribution systems was developed to provide for simpler installation techniques. The solid center conductor of the coax mates directly with brushes inside the female "F" connector, unlike other types of coaxial cable.
Always something to fix. Good luck.
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 04-14-2012, 09:01 PM   #8
stowaways's Avatar
1969 31' Sovereign
Ft. Worth , Texas
New booster...check.
New wingman for winngard...check.
Cleaning up end of cable and rethreading connector. Check! Tv works! Thanks for the suggestions...
