Old 06-20-2016, 11:18 PM   #1
springville , Alabama
We did it!
We bought our first Airstream tonight. 76 Overlander, Land Yacht. It appears to be all original and in pretty good shape for the age. Plugged it in at the previous owners location and all that worked was the AC. (Very important here in the south.)I got it home, replaced battery with a trolling motor battery I had here and spent a half hour trouble shooting the electrical system and BAM found a slightly corroded fuse on the ground. Every light that has a lamp in it is working. Also appears most all the 12 volt systems are working. The inverter appears to be newer. ( I see blade type fuses on the side of it.) Tomorrow the wife is going to do some cleaning and I guess I'll try to figure out why the running lights don't work when I connect them to the truck. Maybe I'll air up the plumbing system and look for leaks.
Bruce D is offline   Reply With Quote
Old 06-20-2016, 11:23 PM   #2
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
Congrats! We're as enthused with ours four years later, so enjoy the learning curve (and, I found my wife was more enthused when I pitched in on all the "heavy" cleaning - it maintained her positive attitude!)
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
OilnH2o is offline   Reply With Quote
If I Did a 'Blow Out' Of the Water Lines and No Water Came Out Did I do it Wrong? mrpettit Winterizing, Storage, Carports & Covers 15 12-03-2014 09:51 AM
I did look I really did bennu36 Sprinter and B-van Forum 11 08-12-2013 01:01 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
Rolite or Nuvite? What did you decide? airstreamcaravel Cleaning, Stripping & Polishing 31 10-18-2002 07:14 AM
